My Defy does not want to start cycle it fills with water and that is all
DEFY DTL 125 FULLY AUTOMATIC WASHING MACHINE
  • 291 Answers
SOURCE: defy automaid instruction manual how to use
click the link below for defy automaid manuals and instructions guide:
http://www.defy.co.za/images/Manuals/BEKO_BOOK.pdf
thanks and plse do not forget to accept the solution.
Posted on Apr 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: My washing machine Defy 1300 can't wash, u load
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: i have a defy electrologic washing machine and all
Posted on Sep 19, 2010
caroldon
  • 17129 Answers
SOURCE: Defy Automaid Washing Machine Model
Possible fault of the program controller unit, the program output to the motor when the cycle is in the SPIN mode must be checked.
Make sure that the output is available, check using a multimeter to confirm. If absent then check the program module to confirm.
Posted on Jun 13, 2011
  • 6277 Answers
SOURCE: my defy automatic frontloader washing
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 14, 2011
My defy front loader filled up with water at 2am last night while not in use...flooding my kitchen. the machine tap is always left open, but is active only when the machine has been switched on???
the water inlet valve is faulty and is not closing fully when powered off causing a small but constant stream of water coming into the machine until it floods out the front, you will need to replace the water inlet valve, in the meantime turn the taps off when your not using it
Feb 10, 2017 | Washing Machines
Defy DDW 169 manual
My Defy DDW 169 Dishwasher won't go beyone draining on starting a wash cycle. What is the problem with the machine?
Dec 18, 2013 | Washing Machines
I have defy laundromaid electrologic 720, it does not stop draining the water?
My Defy electrologic 720 goes into washing mode ,but not filling up with water.
Dec 05, 2013 | Washing Machines
Defy DAW370
time to replace timer/electronic control board and fix it.
You can get part from www.repairclinic.com
God bless you
Jul 11, 2013 | Motorola Mobility Defy Cell Phone
Defy dishwasher leaks water only at the end after spin cycle
please confirm if you are referring to a dishwasher or washing machine. Usually the spin cycle applies to washing machine. Check where the water is leaking from. Most likely the drain pump hose is cracked. Need the model number of washing machine to make further suggestions.
Dec 29, 2012 | Dishwashers
I have a defy electrologic 920 washing machine and the drum will not turn
perhaps you have stumbled onto the defy feature? Classic problem.
Mar 20, 2011 | Washing Machines
Defy Laundromaid 1300 has a serious leak. I've checked the filter, and there is nothing in it to cause it to leak. We had a Defy techinician come out and he also cannot find the leak. Please advise...
water pump is not functioning properly, when in spin cycle water in drum pushes up and over the top, symptom is water leaking out the bottom which indicates a leak but its actually the water pump not pumping out all the water. Gets air trapped in the pump which results in air lock and no head for the pump to function properly. Fix is to lower your drain pipe to same level as pump when in spin cycle so that the water runs out freely this will not solve the problem but will allow you to continue washing until you have the problem sorted.
Dec 26, 2010 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
