Question about Xerox Office Equipment & Supplies
Print Engine Fault 9-366 . how can fix this problem Xerox DC5000 ?
2 Suggested Answers
  • 48 Answers
SOURCE: xerox 1000 print engine fault codes 42-334 & 42-335
You can google this information or call customer service from xerox
Posted on Jan 11, 2014
Xerox 1000 print engine fault codes 42-334 & 42-335
Jan 11, 2014 | Office Equipment & Supplies
Print error 09, 005, 40:5069 how do i fix this?
Hi
This error in Xerox 8560 printer occurs when Cyan ink melt heater is on but the ink is not dripping. To troubleshoot this issue please make sure that you are using genuine Xerox ink. If yes then run Clear ISC Fault test to clear the error. The Clear ISC Fault is located in the Internal Diagnostics Function menu.
Also check for broken or wrong type of ink sticks. After this try clearing the fault by running Clear ISC Fault option. If the sticks are also fine then run the appropriate Ink Melt (1,2,3,4) Heater test. If the test fails then there is an issue with the print head.
Daniel Scott
Jun 08, 2010 | Xerox Phaser 8560MFP Laser Printer
Xerox c2424 fault code 37,008.44:54093
There are two things. I most likely suspect that the print head wiper blade has stuck to the print head. Very common problem after a power failure.
Not sure how I didnt see your post before now. But if your still having that problem let me know, I can tell you how to fix it.
Mar 04, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox 4150 continues to jam on first print - "print engine jam"
Chances are you have a buildup of toner on the charge corotron. This is a part of the copier that charges the drum to accept toner. If there's buildup of toner inside or on the grid of the corotron then the charge will be erratic or excessive and cause the paper to jam as it passes by the drum.
Check your user manual on how to properly remove and clean/replace the corotron.
Aug 21, 2009 | Xerox 4150V_P Printer
Xerox Phaser 6350 printer freezes up and restarts by itself.
Hi dpluu:
Try this procedure:
Engine Test Print
Isolate printer hardware problems to either the Engine Control or Image Processor
Board by running the Engine Test print. If the print is successfully printed, focus on
the Image Processor Board or its components (RAM, Hard Drive, Configuration
Card, etc.). If the print fails, refer to Section 4 for print engine troubleshooting help.
1. Press the Test Print button located on the Rear Panel.
2. The printer prints the 600 x 600 test print unless an error status from the Engine Control Board is present. The test button is in the back of the printer and say's Test Print.
Hope this helps
May 22, 2009 | Xerox Phaser 6350/YDT Laser Printer
Fault message comes up after the printer is powered on
That is a print head fault. Most likely the print head itself has failed.
Mar 11, 2009 | Xerox Phaser 8550DX Laser Printer
Phaser 8550 printer fault 37,008.44:25860
This is a pre heater error.
I would make sure the printer is connected directly into the wall and not into a power strip or UPC as these devices may create momentary AC voltage sags that could cause this error. If power levels going into the printer are good, you will need to contact Xerox for support
Jan 13, 2009 | Xerox Phaser 8550DP Printer
Xerox phaser 8500 fault 37,008:44:11605 What is it?
The 37 series faults are usually due to the failure of one or more heaters in the print head. Usually a comparatively inexpensive fix if its just the electronics module(part no:119649580). You will definitely need a tech's assistance to fix it. If the printer is under warranty they XEROX should do it for you free of cost. Hope that helped.
Sai.
Jan 12, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 7750 Fault 9-913
Use the following procedure to troubleshoot Error Codes 009-910 through 009-913
1. Check the installation of the Print Cartridge. 2. Clear the Tech Rep Fault for errors 009-910 through 009-913 (see instructions below). 3. Try changing the indicated Print Cartridge. 4. Check for an open wire or poor contact between the Print Cartridge and the Engine Control Board. a. Yellow, J-151 to J-405 b. Magenta, J-152 to J-405 c. Cyan, J-153 to J-405 d. Black, J-154 to J-405 5. Replace the engine control board
NOTE:  Before troubleshooting for an open circuit (Step 4) or replacing the Engine Control Board (Step 5), clear the Tech Rep Fault for any of these codes first using the following steps: 1. Enter Service Diagnostics. 2. Highlight NVRAM Access and press OK. 3. Highlight Clear Tech Rep Faults and press OK. 4. Highlight link codes 009-910 through 009-913 and press OK.
Hope my info solves your problem..... Thanx for using fixya......
Oct 24, 2008 | Xerox Phaser 7750DN Laser Printer
23 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
