Question about Canon PIXMA MX300 All-in-One Printer
How to fix a paper jam when there is no longer a paper jam
    Master:
    Sergeant:
  • 226 Answers
Try to unplug it and wait about 10 min and see if there is anything in there at all reboot the system and then plug it back in and try to print a test page
Posted on Jul 21, 2009
Brother mfc 8670 paper jam duplex
remove the small, or scratch into pieces inside the duplex to clear the paper jam.
Feb 10, 2014 | Brother MFC-8670DN - 30 PPM Multifunction...
Exit jam
have the machine perform a paper path test with just 1 copy to see if this jams then have it path test 5 prints to see when it jams- if its only jamming when more than one sheet is being printed then the fault lies with the paper pick up ( you may notice a longer delay for first print)
the machine will attemp to feed three times before failing as a jam
if the machine is printing more than one sheet then the jam appears just before the tail end of the first print exits the fuser (fixing Unit).
clean or replace the feed rollers.
if the jam happens on every print and the code is 13:02/3
then paper pass sensor arm 2 has stuck (look on you tube to resolve this search for lj4200 13:02 jam)
hope this helps- if you are still unable to get the machine working and your willing to pay then I would suggest Belmonte Buisiness machines
are a good company to deal with they are on 0161 480 5556 and can call out anywhere in the UK
Jan 26, 2014 | HP LaserJet 4250n Printer
I want to print an oversized long paper (1meter length) but printer setup limits custom paper size. Need custom driver or other solution.
Sorry but there is no solution. If the paper length is longer than the specification allows then the printer will jam every time based on the paper sensor timing. It will see the longer paper as the paper having stopped and result in it thinking it has jammed.
Sorry
Dec 23, 2009 | HP LaserJet 1010 Printer
Jam in bin
this is a common fault. look where the paper was jammed, you may need a torch. There is a black or white sensor there that has been dislodged. Once clipped back into place it will then report to the printer that the paper path is clear and no longer a jam.
Oct 05, 2009 | HP Color LaserJet 2600n Printer
Paper getting stuck in the rear of Brother 2820 fax machine...
Hi, There are many reasons for jams in the exit of machines and I will list the most common for you damp paper will curl as soon as it hits the fuser rollers... the fix - change paper the fuser rollers are worn (teflon coating is no longer able to deflect toner) and jams are occurring.... the fix - replace the fuser unit
Jun 09, 2009 | Brother IntelliFax-2820 Laser Fax
Paper jam light is on with no sign of a jam printer wont print.
1-paper is most likely stuck in the fuser, (where it exits and gets hot) you will have to remove it
2-it would be better to clean the rollers w/ alcohol then inside out.
Oct 09, 2008 | Dell 1700n Laser Printer
How to clear internal paper jam on CLX-3160FN Samsung Multifunction Printer
Get rid of it. Your problems will only get worse. Mine is going to the landfill.
May 18, 2008 | Samsung CLX 3160fn All-In-One Printer
Deskjet printer problem -paper jam still remains on the coputer mode.
my printer can't start a message appear : one of the composants may be expired
Dec 29, 2007 | Computers & Internet
if you have removed the paper and any paper that might have come off then turn the printer off and then back on to reset it, if that doesn't work, unplug it and plug it back in if that still doesn't fix it you have a loose piece inside yet.
Dec 02, 2007 | HP All-in-One Printer
Canon PIXMA MX300 All-in-One Printer Logo
118 people viewed this question
old marine
old marine
