Question about Apple iPhone Cell Phones
Iphone is not charging cleaned and updated and reset
RESET CODE OF Apple iPhone 4S 16GB MD234LL
Your Question is not making any sense...
What is RESET CODE OF ????
Have you got the latest iTunes?
Open up iTunes on your computer (Windows or Mac) then connect the iPhone to the USB Port via Charge Cable.
Make sure your connected to internet.
In LH Column click on your iPhone or it's Name.
(If there is no LH Column,
Go to View in Top Menu and select Show SideBar)
Click the BACKUP button. This does a backup of your iPhone software.
Check for updates. Your iPhone should be updated to IOS 7.1.2
That updates it's security & gets rid of any bugs & adds the latest capabilities.
This will also reinstall the full clean new IOS.
Hope this helps
Cheers Trevor
OVERVIEW iPHONE 4S
IntroducedOctober 2011 (16, 32, 64 GB) September 2013 (8 GB)
DiscontinuedSeptember 2012 (32 GB and 64 GB) September 2013 (16 GB)
Model IdentifieriPhone4,1
Model NumberA1387 (Worldwide), A1431 (China), MD234LL
EMC2430
Initial Price$450 (8 GB) $649 (16 GB) $749 (32 GB) $849 (64 GB)
Support StatusSupported
ColorsBlack or White
Weight and Dimensions4.9 ounces, 4.5 H x 2.31 W x 0.37 D inches
DISPLAY AND STORAGE
Display Size3.5-inch (diagonal) widescreen
Display Resolution960 by 640 pixels (326 ppi)
Capacity8, 16, 32, or 64 GB
Input MethodMulti-Touch
PROCESSOR AND MEMORY
ProcessorApple A5
Processor Speed1 GHz (running at 800 MHz)
Architecture32-bit
Number of Cores2
Graphics CardPowerVR SGX543
Built-in Memory512 MB
Aug 06, 2014 | Apple MD234LL/A iPhone 4S 16GB AT&T Mobile...
IPhone 4 shuts off expectantly after updates
it seems your update was not properly installed
make sure your device is atleast 80%charged before starting updation in future
go to istore nearby
they have master os to reset it
Dec 26, 2013 | Apple iPhone 4 Black Smartphone
Iphone won't charge unless it is completely powered off
Luckily, there are some tracks you can try to fix it.
iPhone wont charge when turn on
# Check Charging Accessories
# Clean Charging Port
# Hard Reset Your iPhone
# Using iPhone Recovery Mode
# Restore iPhone to Factory Settings
http://www.recoveryiphone.net/article/fix-iphone-wont-charge-when-turn-on.html
try practical methods to fix your problem, and if it still can't get your problem solved, just take it in for service at the nearest Apple Store in your area to get the help of the Apple employee.
Mar 20, 2013 | Apple Iphone 4s latest Model - 32gb -...
3gs Iphone will not charge
get a toothbrush and some methylated spirits, and clean the charging jack on the iphone, as it is most probably corroded. make sure the phone is off first. and just scrub it for a good minute.
good luck\\
nick
Jan 02, 2010 | Apple iPhone (16 GB) Smartphone
IPHONE STUCK ON USB AND ITUNES SCREEN CANNOT CHARGE
It's sounds like your iPhone is stuck in recovery mode
Try this
Sep 23, 2009 | Apple iPhone 3G
My 3g iphone cannot connect to itunes
This happened to me but finally fixed it tonight after many hours of tshooting and searched all over but could not find answer, My wifes Iphone works no issues but try reset network on iphone = Setting/general/reset/reset network settings/reboot ( but you will need to re-enter PIN or passcode) log off Itunes = Setting/Store/sign out (or u might want to update your account info, credit card etc....) good luck!
Sep 10, 2009 | Apple Computers & Internet
I downloaded updates on my iPhone 3G, did a reset as required after downloading updates and now my iPhone wont charge, I press the on button top right even hold it for 10sec with and without home button...
Held the home button and power button for 10sec, released the power button after apple icon appeared and continued to hold the home button until the USB cable icon appeared (this action prepares the iPhone for Factory reset), now connect iPhone to iTunes and follow the prompts! Note: when you restore your iPhone everything will be deleted to Factory Settings and you will only be able to retrieve your settings to the most recent back up you have stored, any data not stored in iTunes, example: (SMS, appointments in Calender), will be lost!
Sep 02, 2009 | Apple iPhone 3G
Itunes screen locked on iphone
Try a hard rest hold the home button and sleep button at the same time till the phone resets its self MSG back if you need more help or does not work
Mar 05, 2009 | Apple iPhone Smartphone
Dead iphone
OK dont worry about what Jamer2004 said. I kmow how to fix ur problem these are the steps
1) make sure ur iphone is fully charged
2) then u need to connect it to ur comp.( MAKE SURE U HAVE THE LATEST VERSION OF ITUNES)
3) now you need to turn it off because it will turn on when u connect it because it will charge.
4) FOLLOW THESE DIRECTIONS CAREFULLY.
5) ok now that its off and connected, U are going to push the top button and the home button for 10 seconds and u are going to release the TOP BUTTON ONLY and keep holding the bottom home button until a itunes sign and a charger cable appear u have just put it into RECOVERY MODE now the computer will find it.
6) the computer will say " A IPOD HAS BEEN FOUND IN RECOVERY MODE, THIS IPOD IS DISABLED UNTILL IT IS RESTORED. or something like that go ahead and restore it and ur problem will be gone and ur iphone will be fine. P.S. please rate :D
Mar 02, 2009 | Apple iPhone Smartphone
Cell Phones Logo
20 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
