Question about Apple iPhone Cell Phones
Iphone 6p is not charging soft and hard resets done updated software still is not charging when the phone turns on the battery icon is not charging randomly the phone will show a charge of 20-30%
    Problem Solver:
  • 11 Answers
It is faulty. probably battery failure but could be the lighting connector. An Apple store will be able to test it for you.
Posted on Nov 16, 2017
SOURCE: my iphone wont charge
I had this exact problem too - same as the first two posts anyway.
It seems to be just a software issue and was easily resolved for me with a full power off and reboot. Here is how to do that safely.
Plug in the phone using the wall socket charger, leave it for a few hours to get a charge (i know it doesn't look like its charging). Later, press the on/off button. The battery icon appears with just a thin red line. Let it go back to black. Then press the the on/off button and the menu button simultaneously for about 8 seconds. A red button should appear on the screen with a question asking if you want to power off the phone. Say yes. (I think it was a slide bar, but can't remember now.) Wait a few secs while the phone powers off. Then remove the power plug from the phone. Now reinsert the power plug. After a few (worrying) seconds of nothing, a white Apple logo appears in the middle of the screen, a few more seconds and the iphone main menu appears. No data has been lost, no settings are altered, and best of all, the battery shows a full charge and seems to be back to normal again.
Posted on Dec 31, 2007
  • 4889 Answers
SOURCE: iphone battery is not charging
The recovery mode trick worked for me too! Thanks guest!
Posted on Dec 02, 2008
  • 762 Answers
SOURCE: HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
Posted on May 12, 2009
SOURCE: iPhone not charging, not recognized
You need to restore whit the last version of iTUNES and an ofiial firmware. Then apply jailbreak.
Posted on Jul 03, 2009
SOURCE: Iphone Battery died now it wont charge or turn on
Hello ! I was in panic attack !!! did everthing and nothing seems to wake up my iphone. I forgot to charge it so battery went full empty, then I plug it on the wall charger, and nothing happend. I let it all nite, and next morning,... surprise !!!!! still the red icon, No battery, the iphone didnt restart!!!! How I fix it?
1-unplug it from the wall charger 2- press middle button and startup button, same time 3-when red battery dissapear, plug the charger. 4_ do this many times. Didnt work for me the first time, but at the end it works !!!!
Posted on Oct 13, 2009
Lights up than turns off
Sounds like the battery or the software could be corrupt. If you try turning on when plugged in to the wall or a computer does it come on?
If it still doesn't then the phone needs a hard reset - this can be done by following the steps in this link How to Hard Reset an iPhone
Mar 31, 2014 | Apple iPhone Smartphone
My iphone screen is completly black i've tried holding the home and the off button down at the same time and its still not working wtf . i really need help !!
Hi, this happened to me once and I researched a fix by looking for 'iPhone black screen of death'
Here's one of the current articles that comes up under that search:
1) If an application (such as Safari) is frozen, just press and hold the iPhone's home button for about 5 seconds, or until the home screen shows up. (This didn't work for my iPhone so we had to perform a soft reset).
2) To perform a soft reset, press and hold the iPhone's Sleep/Wake button and the Home button for several seconds, or until you see the apple logo on the screen. (This action did reset my iPhone and I was very happy at this point). The guys that helped me said that continually performing soft resets can cause problems however.
3) Hard resets are not recommended, but are required when a soft reset won't do the trick. The Apple Geniuses wouldn't tell me the key combo to perform a hard reset because it restores the iPhone to a state that's unusable. Users risk losing data and you must synch your iPhone with iTunes to make it function after a hard reset.
Also, if you are not turning off apps after use they could be overloading things and might cause it to happen again. to turn off apps do a double tap on the 'Home' button, and all your open apps will be listed along the bottom of the screen. press on one icon and hold until the icons start to wobble and have the X in the top right corner click on these to turn them off. Its also good practice to do this several times a day if you use a lot of apps because having ghem open eats up your battery power.
Apr 17, 2013 | Apple iPhone Smartphone
How do I fix my iphone which is frozen up.
Recharge your iPhone. Plug it into a power outlet using the USB cable and power adapter that came with it. Within a couple of minutes, your screen shows a battery icon with a red sliver of power. Don't use your iPhone for at least 10 minutes or until the battery icon turns green. Your empowered iPhone should now be fully functional again.
Force a faulty app to quit. Press and hold the "Sleep/Wake" button on your iPhone's top-right edge. Release your hold when a red slider appears onscreen. Ignore the slider and press the "Home" button for six seconds. Your iPhone should return to the home screen, fully operational.
Force your iPhone to restart. This technique is especially helpful when your iPhone refuses to turn off normally. Simultaneously press and hold the "Sleep/Wake" button and the "Home" button for about 10 seconds. Ignore the red slider that appears onscreen and release your hold when the Apple logo appears. Wait for your device to reset itself to normalcy.
Reset your iPhone's settings if your device allows access to them. Tap "Settings," followed by "General." Then tap "Reset" at the very bottom, followed by "Reset All Settings." This restores your device settings to its original factory condition and eliminates any conflicting settings that may have been caused by changes you recently made or a newly installed app. Your songs, music, videos and other data remain intact.
Update your iPhone's software. If a software bug caused your freeze, the latest software may have resolved it. Launch iTunes on your computer and then connect your iPhone using the USB cable that came with it. Click on your iPhone's name when it appears under "Devices" in the left sidebar, followed by the "Summary" tab above the main pane on the right. Click "Check for Update" and then follow the prompts to download and install the update.
Restore your iPhone if all else fails. This resets your device's software and hardware settings to factory conditions, removes all data and then restores everything from a backup. With iTunes launched and your iPhone plugged in, click on your iPhone under "Devices" on the left, followed by the "Summary" tab on the right. Click "Restore" and then "Backup" in the pop-up dialog. Prepare to nurse your iPhone through this process for 20 minutes or more. When done, resynchronize your iPhone in iTunes.
Jul 24, 2012 | Apple iPhone Smartphone
My iphone is not showing the chargfing icon yet it is charging, slowly
You may please keep in mind that iPhone battery may drain instead of charge if iPhone is connected to a computer that's turned off or is in sleep or standby mode. If you charge the battery while syncing or using iPhone, it may take longer to charge. About not showing the charging icon, please try resetting the phone by pressing the Sleep/Wake Button and the Home Button both simultaneously after which the phone restarts after some time with apple logo on the screen. -- MS Ramakrishna
Oct 13, 2010 | Apple iPhone Smartphone
My iPhone 3GS battery died and now I get only a white screen...
Try hard reset
  1. Press the home button (the big circle below the screen) and the sleep wake button (the button on top of the iPhone) simultaneously.
  2. Hold both buttons simultaneously for a few seconds, Ignore the "Slide to power off" and keep holding
  3. The iPhone should now shutdown automatically - (fade to black)
  4. Turn the iPhone back on by hitting the sleep/wake button.
  5. You should now see the Apple logo, your iPhone is restarting and thus booting up.
  6. You have completed a hard reset successfully
Jan 08, 2010 | Apple iPhone Smartphone
My iphone wont charge
It can also be the battery. Maybe you need to change it.
Aug 07, 2009 | Apple iPhone Smartphone
How to update/reload my Nokia 7610 software without taking it to the customer service center. Pls. suggest
if you are aking on how to soft reset the system to factor settings then the code is
*#7780# This will soft reset your phone all data, like contacts, calendar and notes, are not removed It will only reset the phone settings, such as profiles, themes and shortcuts.
*#7370# This will also reset your phone all data, like contacts, calendar, notes, profiles, themes and shortcuts are removed. The default lock code is 12345.
there is another way to hard reset you phone completly
make sure battery is fully charged and first switch off the phone then
hold the Green button + *button + 3button and Power button and wait till Formatting appears on the screen
all data will be lost on the phone (not memory card)
pls rate if it was any help
Jul 05, 2009 | Nokia 7610
IPhone not charging, not recognized
Apr 14, 2009 | Apple iPhone Smartphone
My Lowrance LMS-337c df keeps going crazy.
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}This could be caused by glitch in the operating systemsoftware or by low voltage due to a short in the unit or somewhere in the boatswiring. To troubleshoot the problem Iwould recommend the following steps.
  1. Try a soft reset
  2. If the problem resurfaces, try a hard reset
  3. Update the the operating system software
Soft Reset (Does not delete GPSData)
1. Turn unit OFF 2. Press and holdthe PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map
Hard Reset (Deletes stored GPS Data
such as Waypoints and trails)
1. Back up any waypoints, routes,and trails that you want to save on a blank MMC card
2. Turn unit OFF
3. Press and hold the ZIN&ZOUTKeys at
the same time
4. Pressand hold the PWR key
5. Release both buttons when the USAmap
To update the operating system software, check out this link:
Lowrance337c df update
If you don't have a card reader I can program an update card for you.
Dec 15, 2008 | Lowrance LMS-337CDF GPS Receiver
Cell Phones Logo
27 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
