Question about Invacare Health & Beauty
Was making a chatering noise when fist get going now nothing just a clicking noise and will not go forward or backwards
This is a invacare auriga 10 mobility scooter
  • 61 Answers
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
Posted on Mar 19, 2010
  • 177 Answers
SOURCE: invacare auriga looses power
Hi. Most probably its the throttle pot ( Wig Wag ) thats causing the problem. I am an Invacare service agent and I have changed these many times for this very reason.Also check motor brushes are not worn down or jaming. Good luck. Neil.
Posted on May 30, 2010
  • 177 Answers
SOURCE: have Invacare Auriga 4 scooter about 2yrs old Put
Hi. I have had a few scooters that have had this problem after sitting for a while. The brake lining is stuck to the body of the brake assembly. When the brake is energised by the controller, it can't release.
De-clutch the machine like you did, and try rocking the machine back and forth. If this doesn't work you might have to have a new brake assembly fitted.
The wheels turn in opposite directions, because the drive is through the differential unit in the rear axle. Even a car will do this if the driving axle is raised in the air.
I have also had a few cases of stuck motor brushes in these machines, but from your description, I would say it is the brake assembly.
Good luck. Neil.
Posted on Jun 14, 2010
Testimonial: "It was a frozen brake. I took the brake to pieces,a lot of little springs spacers indent springs and rollers jumped out. Cleaned all components and spent a few hours figuring it out for re assembly. Working fine now . Thanks for your prompt and accurate reply. PeterR"
  • 1267 Answers
SOURCE: where can i buy replacement carbon brushes for
Since these are special made electric motors, you are going to have to go back to the dealer that sold you the machine and have them order the parts (brushes) for you. The PDF file for these scooters are found at:
http://www.invacare.co.nz/***/content/328/349/auriga-spare-parts-june2010.pdf
page 6 will give you the parts number.
If you are mechanically handy(I suppose so as you intend to replace brushes), then you may want to try a maintenance trick first of all. Generally these brushes are are not used up in a DC motor, but fail due to the carbon build up on the armanture of the motor shaft or the wear of the brushes have become so concave that they are making only slight contact on the armanture. If you can, pull the end off of the motor and lightly clean the armanture contact. Clean with some alcohol. Then examine the concave of the brushes, and using an emery board file the points of the arc in the brushes so that you change the deepness of the arc, bringing the center closer to the contact. re-assemble and test.
Posted on Jan 22, 2011
gfreed100
  • 60 Answers
SOURCE: invacare auriga runs well but no headlight or indicaters any ideas
What you got to do is what we call "chase the voltage" First you will need a 24v circuit tester
http://www.amazon.com/OEM-25886-6-24V-Circuit-Tester/dp/B0014WIVX6
You may also need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
The problem is 24volts is either not getting to the tiller head or you have a broken wire in the tiller head. Start at the headlight make sure its switched on. Use the circuit tester, put the clamp to ground, use the probe to find the 24volts, The hot side is the side wired in series with the switch. The tester will light up when it has voltage. Chase the wire back through the system. When you get to a cable or anywhere you can't see the wires use the VOM meter, disconnect the scooters batteries leaving the power switch on. Set the meter to read resistance scale high scale, short the probes together, zero the meter. Put one probe at the headlight the other probe at the connector you think the wire ends up at. Normally every wire is a different combination of colors like red; with a white stripe. Most of the time a wire ends up at a connector and the color code doesn't change. So if you are not getting continuity on any of the pins on the connector you know its got to go, you've isolated the open circuit too the tiler head. Here's a test you can run! Turn headlight on, power on for scooter, disconnect scooter battery, place one probe at head light. Disconnect tiller cable. Probe each pin, one of them hast to cause the meter to deflect to zero. If if doesn't the problem is in the tiller head. When working with little wires i like to use crochet needles. You can use the meter to check cables each pin in must have a pin out. If you don't get continuity between pins the cable is bad toss it.
Posted on Jun 07, 2012
Invacare tdx sp electric wheelchair runs fine but every time my husband stops and goes it makes an annoying clicking noise just when he is going forward or backward
That clicking is a electronic motor lock disengaging when you start and re-engaging when you stop. That is quite normal though some are louder than others. You cannot make it any quieter than it is.
Feb 06, 2018 | Invacare Health & Beauty
Mobility scooter lights wont turn off
It really can only be one thing. Somewhere on your scooter is a switch for the lights. Try turning it off. If that doesn't work the switch is faulty
Nov 01, 2016 | Invacare Health & Beauty
Invacare auriga 10 Hi from Australia.I have just been given a Invacare Auriga to try to fix for a lady. Horn stuck on so some time ago, somebody disconnected it.Dont know if that is an indication of
Disconnecting the horn, in most cases, should not affect anything else as long as it was done correctly. Beyond that, I have no idea what the question here is.
Mar 22, 2014 | Health & Beauty
Where can i buy replacement carbon brushes for auriga 10 invacare scooter (6 mph model)
Jan 22, 2011 | Zoom 220 HMV 3-Wheel Travel Scooter
Hear a clicking noise when backing up and forward
if you hear that clicking noise whether going forward or backward,,it's most likely a bad cv joint on your axle going bad,,or bad. you'll need to replace the axle it's coming from. just have someone listen to the noise while you're going forward or backwards while turning the wheel in motion to determine which axle is bad! hope this helps!!
Sep 16, 2010 | 2002 Volvo S60
Have Invacare Auriga 4 scooter about 2yrs old Put into stores about 6 months ago was working fine battery's have always been on charge. Cannot get scooter to move. When I put de-clutching lever in to...
Good luck. Neil.
Jun 13, 2010 | Health & Beauty
Invacare auriga looses power
Mar 21, 2010 | Health & Beauty
Health & Beauty Logo
65 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
