Question about Cell Phones
Curtain wall systems clad a building envelope with glass and aluminum to protect the interior from the elements and creates a safe and comfortable work environment for the building occupants. Curtain walls are designed to only carry their own weight. The wall transfers wind loads to the main building structure, also known as the main wind force resisting system MWFRS, at connection points in the floors or columns of the building. A curtain wall is designed to resist air and water infiltration, as well as, sway created by wind and seismic forces, and its own weight. With unique texture, rich color and durability, aluminum curtain wall appearance and shape can be diversified, and it has perfect combination with glass curtain wall materials or stone curtain wall material . Curtain wall aluminium profile has perfect appearance and good quality, so much favored by the owners. Its light weight, only one-fifth of marble, one-third of galss curtain wall, significantly reduces the load on the building structure. What's more, aluminium curtain walling casts low in maintenance, which makes it a cost-effective material. On the current market, the vast majority of curtain wall aluminum is composite aluminum or aluminum veneer. HAOMEI offers a range of installation and aesthetic options to meet your project needs. Our curtain wall systems are available with; inside, outside or structurally glazed options. Our stick built, unitized, and cassette carrier frame system options are available with many site lines and mullion depths allowing you to control cost by selecting the ideal mullion depth for your opening size and design pressure requirements. Optional face covers expand design flexibility. Facts About Haomei: BILLET CASTING Haomei Aluminium Co., Ltd has international advanced smelting equipments, including six 20-ton smelting furnaces, four casting furnaces and two homogenizing furnaces. The operating of these equipment has not only improved the production efficiency, but also stabilized the quality of aluminium bars and aluminium profiles. The internal laboratories' modern computerized control system ensures the quality of different alloy components. This high capacity of production enables HaoMei to meet all customers' needs. EXTRUSION In HaoMei extrusion workshop, there are 26 extrusion presses of international advanced level, of which one set of 4000 tons, one set of 3600 tons, two sets of 2500 tons, five sets of 1800 tons, nine sets of 1250 tons and eight sets of 600 tons. The annual capacity of aluminium profiles is 150,000 tons ALLOYS TYPES HaoMei can produce different series of alloys in architectural, industrial and automotive industry. We handled more than 100 series and 8000 items. In addition to the 6000 series, we also developed 2000, 3000, 5000, 7000, etc. With better mechanical properties, these series could easily replace steel components in different industries.
My shower door has an opening above the shower door. Can I enclose this are with an aluminum louver type window that can be partially closed to give a sauna effect; and opened for a normal shower?
you could but you will create lot of moiseture that your shower area is not build as a sauna ,,means you will trap moistture in the wall and turn in to a black mold..
Apr 23, 2015 | Cars & Trucks
Defrost ge regrigerator
The most common problem with the defrost system is a burned out defrost heater. It is located behind the frz back wall usually attached at the bottom of the aluminum cooling coils which will probably be full of ice and frost buildup. You will need to melt all the ice off the coils with something like a hair dryer. The heater is inside a glass tube and can be tested with a multimeter or sometimes you can see the break in it through the glass. In some cases there are 2 or 3 heaters at different levels. Replacement kits should include as many as needed for your model. Replace them all. 2 other parts to the defrost system are the defrost timer (usually located on the front channel under the freezer door) or the termination thermostat which is a silver disk clipped to the top of the aluminum cooling coils with 2 wires going to it. Any of those 3 parts could cause the frost buildup but the heater is the most common.
Apr 05, 2015 | GE Refrigerators
Is there a way to make a stud wall for a shower part transparent?
You mean clear plastic dry wall? or how about a window? How about removing the wall and putting in glass panel? Glass block? Anything can be done, depends on your imagination. An exterior wall can be totally removed with a lintel replaced in the top, and interior wall can be totally removed with no lintel, depending on trusses, or rafter placement.If you want to leave the studs exposed in the wall, I would clean them up a bit. The problem with that is you can't clean it and the panels are subject to fogging up inside, condensation will get in there, an exterior wall is a bad idea, no insulation. Hope this helps.
May 20, 2010 | Basco Semi-Frameless Tub Shower Enclosure...
Refrigerator not cold, freezer barely cold and has ice on back wall
You have a defrost problem if the ice is on the back lower wall of the freezer section.... This is where the evaporator is located just under a fan.(aluminum coils looks like a radiator) There are three parts to the automatic defrost system- the heating element(found at the bottom of the evaporator) a bi-metal thermostat(found at the top of the evaporator) and a defrost control board(usually in the top of the refrigerator section,but this varies)
If you take off the back freezer panel and melt the ice build- up with a hair dryer or letting it open overnight, without poking any holes in evaporator and losing freon(out a fridge) your fridge will run fine for about 3 weeks. This is humidity from air collecting, automatic defrost system usually works about every 8 hours when working normally. Your sealed system and compressor are fine, you have a defrost problem. Good luck.
Mar 14, 2010 | Maytag MZD2766GES Side by Side...
We are having to replace a single wall oven, electric. the wires coming out of the wall are aluminum. Are they acceptable to use?
I would say yes, using the proper connectors, but local electrical codes may vary. You should confirm with a local electrician or building inspector.
Nov 20, 2009 | Washing Machines
Wall Lights from outside
Normally it is not allowable to run a regular cable (such as a Romex) where it will be exposed. Which it sounds like this cable will be run. Your best bet to make it a legal and safe install is to use a metal clad, or armored type cable (called MC, BX, or "greenfield" by some).
Jan 30, 2009 | Electrical Supplies
Foil stuck to bottom of oven
A bit of chemistry first. Aluminum foil reacts to acid. A black substance referred to as aluminum salts is formed. This is simply wiped away. How quickly the foil is converted depends on the strength of the acid. Vinegar has a safe level of acid content. Within two hours, some aluminum salt should have formed. Wipe it away. Repeat. And keep repeating until all gone. Yes, the process takes time but you can be doing something else. And the salts are black, so you don't want your clothes or hands covered by the black. Expect this to take a long time. And you may get frustrated and decide to buy a new liner! But if you work at it long enough, it will remove the foil. You may be pickled by the end of the process but repetitions of this will remove the foil ... in good time ...with enough applications and wipings. And you haven't been exposed to fumes or effects of sodium hydroxide.
Jan 10, 2018 | LG LRE30757ST (Electric) Stainless Steel...
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
