Question about Vacuums
I picked up an older delta 6" precisionjointer and need to replace the knife roller bearings and need part #'s. all I see on the parts are casting #'s. NJ227 overhear, and NJ228overthere.
2 Suggested Answers
SOURCE: I need a "Bearing Assembly" for roller brush 61445-1,I Have a GE 106575
From the manual that came with it, the bearings are non-serviceable, and the whole brush roller needs to be replaced... Originally part 61445-1 was $15.89 + $5.50 postage & handling in the USA only. I don't know what it would be now.
Posted on Jun 15, 2016
What is wrong...My Eureka commercial vacuum C2094g smells like burning rubber, replaced belt (style RD) but it was smaller in size and very hard to put on. Am I using the wrong belt? it looks like the...
Replace the Roller Brush. Sounds like bearing in it is locking up and the the belt is slipping and not turning the Roller Brush as it has a locked up bearing. You will need to go ahead and get a replacement belt just in case you have stretched the older belt to a bigger size. I had this same experience with a Hoover and it solved my problems of "rubber burnt smell".
Apr 27, 2014 | Hoover S3765-040 WindTunnel Bagless...
My Kenmore Progressive Whisper Belt canister vacuum is not "whispering." In fact, it makes excessive noise during operation - much more than the older Kenmore model that it replaced. I have replaced the...
Probably either bearings in the roller brush, a damaged fan blade, or the bearings in the motor. Take the roller brush off completely, and run the VAC without it. If it's much more silent, then the problem is with the bearings in the roller brush. If it's still noisy, then look closely at the fan that produces the suction, if you can. If you see any damaged blades, then you'll have to replace it. If it seems fine, then it's most likely bearings in the main motor that will have to be replaced. The bearings and the fan blade are NOT expensive parts, but the labor at a shop to change the main bearings would be kinda pricey.
Oct 18, 2013 | Kenmore Vacuums
How do you go about cleaning the rotating brush on the dirt devil bagless vacuum?
Using a sharp pocket knife or a utility knife making a single cut across the length of the roller is a good way to start. Then it is just a matter of pulling the strands or fabric and hair, etc., off. I like to inspect the end caps and bearings as well. A touch of grease of oil can help increase the life of your roller as well. ( for the bearings)
Jun 10, 2011 | Dirt Devil Featherlite Bagless Vacuum...
Lost manual on vacum need to replace belt
Remove the bottom cover of the sweeper head, then remove the brush roller along with the belt if still there. Clean the brush end-bearings--the roller ends and the interior of the bushings. Then oil the bearings lightly with 3-1 oil or similar. Place the new belt over the roller and the motor shaft adding any required belt twist (diagram on the casting), then seat the roller and bearings as a unit. Replace the cover and test the roller for running. Hope this helps!
Oct 08, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Belt keeps burning and breaking
Hello There,
It sounds like you need to replace the roller brush. If your Bissell is breaking belts that fast, then that can only really mean one of two things. The first being that the belts are not being properly installed, and the roller brush is pinching the belt which causes the belt to break, but after 3 belts I doubt this to be the case.
Probably the more likely problem is that the brush roller's bearing have seized up. You may test this by removing the roller brush from the vacuum, and holding it with on your two pointer fingers holding the outside bearing caps of the brush, making sure not to touch the actual part that spins. Now try to spin the brush while holding the bearing caps with your pointer fingers. The brush should spin freely, and should revolve around 5-6 times with each spin. If the brush doesn't spin easily, then this is going to put a lot more stress on the belt.
You may try to remove the bearing caps on the ends by twisting them off, and visually inspect each side to make sure there is no hair or thread that's lodged inside the bearing cap. This will make the brush hard to spin, and can cause you to burn belts quickly like you have been. You may find the bearing caps will not come off. This indicates that your brush roll has worn out the bearings completely, and the bearing caps have melted to the bearings due to extreme heat. You will then need to replace the roller brush if this is the case, and it maybe the best solution for you if you have burned through 3 belts so quickly.
The roller brush for your Bissell (I'm assuming this is yours as this is where the repair was posted on Fixya) 6594 PowerForce upright uses Bissell roller brush part number; 203-1195. Here's a link if you need to purchase one;
I have uploaded the parts schematic and owners manual to the main Fixya page for your model as well. Sometimes it can take 24 hours for Fixya to publish this data, but please visit the link to these documents in 24 hours or less;
If your roller brush is good, then examine where the brush rests inside of the vacuum cleaner, this is called the agitator housing. Look at the sides of the agitator housing where the bearing caps rest. Do you see any visible damage on either side? Sometimes the brush can get so hot, it may melt the agitator housing on the sides where the brush rests, this will also cause the belts to burn very quickly.
I hope that this information is helpful to you. If none of these suggestions fixed your vacuum, please just add a comment, or request a clarification request here on Fixya, and I'll be happy to respond. If this was helpful, please be sure to rate the repair by clicking on the 4 thumbs up icons in the upper right hand corner.
Thank you,
Chris J.
Mar 23, 2010 | Bissell 6594 PowerForce Bagless Upright...
Replaced belts and brush roller will not rotate.
check to see if the spindle (small pencil-thin metal rod) is spinning where it projects from the motor. the belt wraps around this rod. if the rod is spinning when the vac is turned on your brush roller could be jammed. the bearing in the far sides of the brush roller frequently pick of long threads and hair and will stop the brush roller or the bearings sometimes overheat when worn and plastic will melt in this area causing stoppage.
Jul 10, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Roller and Belt
I have had this vacuum for about 5 years now. You need to change the belt every 6 months. Walmart sells a bag of 3 replacement belts.
May 27, 2008 | GE 106766 Bagged Canister Vacuum
Probably should just go to a repair shop and they should be able to order one for you, that is if they are available by themselfs. Or if you have a store where you live that sells vacuum parts, you could go there.
Dec 08, 2007 | GE 106585 Upright Vacuum
Brush won't spin
Dear Xana,I have had problems like yours before. More times then not the roller brush "belt" got damaged and needed to be replaced.
You should also check your roller brush and make sure it was not knocked out of alignment.
If neither of these solutions help,then it could be, your roller brush "Bearing Assembly"got damaged which would mean you need to either replace the "Bearing Assembly" if it is removable and if you can find that part.Or else you would need to replace the whole "Roller Brush".
You can normally tell if the "Bearing Assembly" is damaged by trying to turn the roller brush with your hands,if it takes a lot of force to make it turn,then theirs a good chance it was damaged!
These repairs are fairly easy to do, just read your Vacuum manual on replacing parts,also make sure you always have the vacuum unplugged while replacing parts or doing repairs.
I hope this info helps,EarlsOK
Dec 08, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
