Why I can set password on riso? - Office Equipment & Supplies
Cant clear e78 error code
CR set to wrong country code in Memory Switch - Setting no. 200 (machine model setting), needs to be "B"
May 05, 2014 | Riso Office Equipment & Supplies
How do I make my MZ 770 Riso accept a different ink so I can change its color? Thanks
These newer models use a different ink. Trying to change the color this way will have disastrous results because the machine will use certain settings for, say, blue ... if Blue is not in the tube, though, you will end up painting the inside of your Riso.
Apr 08, 2014 | Riso Office Equipment & Supplies
Check setting error in d-04-560 Riso CZ 180
saya membutuhkan informasi dimana di surabaya service mesin cetak riso black cz 180 ?
Feb 04, 2014 | Office Equipment & Supplies
The riso rz 390 ui does not print the scans complete
Please check the setting of paper size. It may be set to a smaller format and therefore the outer original area is not transferred to the master.
If you meant someting other than please explain ...
Feb 03, 2011 | Riso RZ390 Duplicator
On riso pr 3700 can not get the full image on landscape mode when I make a master
Maybe you meant model RP3700 ...
These questions may help to find a solution or at least a better understanding of your problem:
Have you set the paper size right?
Is the print drum capable of the desired imaging size?
Mar 31, 2010 | Riso RZ390 Duplicator
Riso rz230 aw has error codes d-04 -534
riso mz series has error codes D04-534 and D44-538
Jan 06, 2010 | Riso RZ220 Duplicator
Riso 390 has error code d4-534
D04-534 means incorrect ink cartridge set. This could be caused either a) it IS the incorrect ink cartridge, or b) the RF tag that is struck to the end of the ink bottle is damaged. Try a new ink bottle.
Make sure to use RISO ink designed and made specific for an RZ230.
Error Code -534 on my Riso RZ 390. Drum is stuck in machine and won't release.
Jan 03, 2010 | Riso RZ390 Duplicator
Riso cr 1610
You will have to select corect machine model in service mode 200 , nomaly it is d but you will have to select between 1 and f to find the corect setting or just make sure that your cable is connected corectly
Nov 12, 2008 | Riso RZ220 Duplicator
18 people viewed this question
k24674
jasbo
jasbo
