Question about Vacuums
My ddw497w is functioning except the sayer wand is spinning around
How to detatch 1950's vintage elecrolux head adapter from the wand
It could be dirty and corroded try spraying it with some WD40 and letting it set for a day and spraying it again, then try it.
Mar 13, 2014 | Vacuums
Head not spinning and sucking up
You share a common misconception. There is nothing to spin except the dust in the canister. All plastic parts are static. If you've cleaned the filters as instructed in the manual (download from Dyson website if you're unsure and have lost the original), the most likely problem is that you have a blockage in the pipework. You need to separate the hose and wand, and remove the hose from the machine, and check all through - you will almost certainly find something that shouldn't be there!
Good luck.
Jun 23, 2010 | Dyson DC05 Bagless Canister Cyclonic...
Wand in stowaway dyson is hard to extend. Seems like u have to pull 3 clips from grooves in 3 rings around wand to extend and shorten wand which is a struggle
Hi there, you should just be able to hold the telescopic wand in one hand, press the button and pull the whole length of the wand out to its fullest position.
If the telescopic wand on your particular Dyosn is very stiff, you may need a replacement.
Your machine may still be under guarantee or warranty. If this is the case, please contact Dyson directly on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Dec 27, 2009 | Dyson "Stowaway" Canister Vacuum Vacuum
Wand will not ****--
it's clogged run water through it. or stick a broom handle or something that will fit in it through, that should do it.
Sep 06, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kenmore Intuition wand very hard to pull out of head.
No vaseline. You can use wd40 or silicone spray.Also check to see if the wand is bent out of round where it meets the handle
Sep 06, 2009 | Vacuums
I can't figure out how to hook up hose attachment to dyson 07
You have a reversible wand on the DC07. You have to separate the wand from the hose first, then turn it around and reconnect it. Once that is done you will be able to use the attachments on the end of the wand. You can also connect your attachments to the hose.
To separate the wand:
1) Take the wand off the back of the machine
2) Place one hand on the Handle and one hand on the gray flexible hose.
3) Push the flexible hose down. You will see a long metal rod appearing. Push until the hose clicks into place at the bottom of the metal rod.
4) You'll see a half-moon shape button with a picture of a lock on the solid gray plastic part at the top of the hose - push it, this will separate the wand from the hose.
5) Turn the wand around
6) Push the purple wand cap with the holes in it back, it exposes a short dark gray pipe, about an inch in length
7) Connect the hose to the short pipe
8) Attach your tools to the top of the metal rod and have fun
Jul 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Rainbow e series vaccum/scubber
If you are talking about the hard wood floor brush you hook it at the end of the one slightly bent wand. Look at the end of the brush that you would hook to the wand. In the circle opening there are two slits. On the end of the wand there are two bumps. You need to line them up, push the brush on then twist it around so it stays on. then you attach the straight wand to that and the other slightly bent wand at the other end of the straight one. It will go like this Wet hose, slightly bent wand, straight wand, slightly bent wand, and floor brush. I hope I helped. Leave the basin empty. put your water or cleaner on the floor scrub it around then turn machine on and suck it up.
Nov 30, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
