How to empty the water tank on the portable air on RHAC 10
SOURCE: Emptying Water
open the big front door, pull the top of the water container toward you, take it out turn it over, unscrew the top, pour out the water
Posted on Aug 26, 2008
  • 659 Answers
SOURCE: wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Posted on Apr 01, 2009
  • 334 Answers
SOURCE: I have a portable air conditioner and the water
I would suggest putting a condensate pump in the reservoir, find the tube that empties the water into the reservoir and direct that into the pump. You can run tubing from the pump to a sink or any other drain in the house that is convenient. Putting the pump inside the reservoir is a safe guard in case the pump fails, the water will fill and turn the unit off instead of flooding the floor. It would actually probably trip your breaker once the water hit the voltage on the pump but always better safe then sorry. Check out these pumps at amazon, you don't need anything fancy.
http://www.amazon.com/gp/product/B000UVUW6Q
Good Luck
Posted on Jun 11, 2009
  • 6 Answers
SOURCE: water going into carpet instead of ac water bucket
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
Posted on Aug 19, 2009
  • 4736 Answers
SOURCE: How do I correctly drain
Yes the tank does need to be drained. There is a short drain hose that was supplied with the unit. It attaches to the hose connection the back of the unit. Use a 5 gallon bucket to drain it with the hose.
Or iis you rather, you can just pull out the tank and dump it in the sink or a tub. Be sure to turn the unit OFF and unplug it, before removing the water collection tank.
I have included a link to the Owner's Manual for a model similar to yours. The instrcutions will be the same. Copy and paste the link into your web browser.
ttp://web1.dlservice.org/dlservice/dataload/istruzio/GB-5715110581.pdf
Hope this helped you. Please let me know. Cheers!
Posted on Jun 23, 2011
Why does my a kenmore portable air conditioner tell me to empty the tank. I can't find any "tank/bucket" to empty.
Should e a drain on the back o f the unit to drain condensate water off. It will not run until yo empty it.
Jul 21, 2016 | Kenmore Heating & Cooling
Water leaks under portable air con unit
Look for a crack on the water tank or a dried up gasket on the tank. Loose hose clamps can allow a leak as well.
Jan 04, 2014 | Heating & Cooling
There is no drain pipe for the unit I have. It has a cap on the back but no hold, how does the condensation.
Self Evaporating Technology - During the cooling process, water is extracted from the air into the unit. Most of this water is then recycled and used to cool the unit and make it run more efficiently. Approximately 65 to 70% of water condensed is evaporated out with the exhaust air, reducing the hassle of emptying the water tank constantly. This unit has a built-in water tank (not removable) with a drain outlet, and a water tube. When the tank fills, the compressor stops operating and the power light will flash. This indicates that the tank should be emptied.
Jul 21, 2011 | Amcor ALTL-12000E Portable Air Conditioner
Changed r/o 3 filters and now water produces 2cups
The pressure on an EMPTY tank should be 8-10 psi. Be sure the tank is empty before checking the pressure. A good way to empty the tank is to connect a small air compressor to the air valve on the tank, open the systems faucet, and turn on the compressor. A bicycle pump works too....Just more of a workout:)
Jul 08, 2010 | Culligan Sales #SY-750S Under Sink Water...
The E5 code is on, emptied the water tank; still on
AC Water Level Sensor for C475 and C360 Alen Portable Air Conditioners This is a replacement water level sensor for the C47store.alencorp.com/product-p/acwaterlevelsensor.htm. Check out this sight. Good luck
Aug 31, 2009 | Alen C475 Portable Air Conditioner
Emptying Water
Jul 23, 2008 | DeLonghi Pinguino PAC-210 Air Conditioner
Full Tank very fast
witch model do you have, for some models thats normal on others its not, some run the water over hot coils and it evaporates others the water goes into a holding tank and sits their til the tank fills up then you must empty. expect more water when high humidity or in the summer
Jun 27, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
