Question about Sony Handycam DCR-TRV340 Digital Camcorder
Trv340 error code c:31:23
Not able to play, record, FF, RWD, & tape gets stuck, with error code c:31:23
Please let me know your cost to repair and return.
  • 2 more comments
  • raybee Feb 05, 2008
    load tape, then error 31:23 flashes, no response to record, play. This error progressed to error 31:40, almost didn't get tape out: hung up after vertical (1st step) eject, without doing horizontal (2nd step of eject). Momentary closing of door encouraged horizontal eject.
  • sanjay1968 Mar 23, 2008
    I am having a problem when I turn on my vide o camera- plugged in or not that I get a c31:23 error message with an eject sign on the camera. This is the only problem code not listed in my information book and I don't know what it means. I have tried a different battery,letting the camera charge with no tape in the machine (thinking it was overheated) and nothing is helping. Any ideas?
    I get a C:31:23 error message every time I turn on the camera. I have tried everything I know to do, including hitting the reset button and removing the tape. Anyone know of a solution? The camera cannot be used with this error.
  • Anonymous Nov 30, 2008
    I have the same problem.
    Trying to start the camera on VCR or camera position and 31.23 starts flashing with Arrow.
    The manual says that the humidity is the proble...
    Tried all the fifferent ways..of drying the camera..left open for dry area...nothing works
    Anybody knows the solution ???
  • andre26 Dec 15, 2008
    some one find a good answer to c31 32 info on camcorder
According to page 184 of the owner's manual, any error C:31:X or C:32:X you can fix by removing the cassette and re-inserting it again and/or disconnecting the power cord and removing the battery. After doing both of these steps, I'd also recommend using a paper clip and press the tiny reset button underneath the flip out display where all the other hidden buttons are for the camcorder.
Posted on Jun 21, 2008
Toddsh88 correctly quotes the manual's solution. However, my experience was that the solution was temporary at best, usually ineffective. This problem occurred in 2006 and I had it repaired by a respected local vendor. That lasted about 12 months. I bought a second (used) camera (the one failing on 2/5/08). After a few successful tests, it also failed. See picture. trv340 error code c:31:23 - 2e1a5ab.jpgI I had first camera repaired by Sony (factory authorized), and it seems to be working again.
Posted on Jun 22, 2008
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
We had this machine in storage for two years, since then I can set the clock, but that's about it. the front panel indicates commands from the remote but the tape drive ignores these?
Sometimes when a device has no power for some time, certain parts can malfunction. Generally these are electrolytic capacitors, who won't charge up anymore.
Aug 11, 2014 | Televison & Video
Error code 31.23 sony trv 340
Error code 31:23 indicates a fault in the tape transport system. This can be caused by several things including the transmission not engaging properly, a missing pinch roller, a defective clutch in the take-up or a faulty rotary mode switch and will require disassembly to repair. This can usually be repaired fairly inexpensively. However, it's not really a user serviceable problem and should be looked at by a qualified technician. Below is a link to a repair shop that should be able to help you.
Dec 01, 2011 | Sony Handycam DCR-TRV340 Digital Camcorder
I cannot record, in the corner where it says record, standby, it flashes the number C:31:40 I have a new TDK Hi 8 120 and it keeps flashing. Please help, thank
when problem occur while cam is operating, the self-diagnosis function starts working, and may display the service mode display code. in your case, C:31:40, pertains to a part of the cam tape compartment mechanism called the drum that doesn't start up. issues could prevent you from recording, playing back tapes, rewinding or fas forwarding. t/s steps are: try diff tapes esp. w/prev recordings, reset cam (press reset button while cam is on, located just below the menu button, in the panel where the lcd screen goes to), power reset (remove batt and ac adapter and leave cam w/ any power source for at least a minute). if issue persists, unit will require repair. hope this helps.tnx:)
Jul 21, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
A video tape has become stuck in my Mitsubishi VCR
Hi, Suggest call a local tv repair shop. Thanks.
Sep 22, 2009 | Televison & Video
F11 error message in ag dv2700 during play.
I've been working for hours on this machine, cleaning and lubricating the mechanism and trying various adjustments to fix related problems. If I recall correctly the F11 error is due to tape mistracking, indicating damage to same. Someone posted a suggestion that the F08 error indicated a drum relay problem, requiring professional servicing; but it also comes up on my machine if the tape tension is too high and the mechanism cannot overcome it when loading the tape. I only realised this after finally tracking down pretty well all of the bearings needing lubrication; then adjustments to the tape tension could be detected. I've got to the stage that my AG-DV2700 will accept tapes that have been recorded on that machine; playing them instantly, after the usual auto tape tensioning where the tape is FF a few seconds and then RW a similar amount, if the safety shutter is enagaged; and merely accepting them in the normal fashion otherwise. Up until this point it would throw up the F08 error whatever tape was put in; if you switched the recorder back on instantly the tape would slow FF, ie not its usual whirlwind winding, and be available for use after auto rewind at the end. If a tape NOT recorded on it is put in it still stops with the F08 error. I would suggest that trouble with this recorder is likely due the loading mechanism becoming stiff. All you have to do is dismantle it - but there's lots of tricky bits and bobs in there to watch out for.
Mar 09, 2009 | Panasonic AG-DV2700 Mini DV VCR
Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Code 3L117C ???
None that I could find. Trash time for this Sony
Dec 10, 2007 | Sony SLV-798HF VHS VCR
Will not record or play back.
the head may be dirty, try cleaning the head with a cleaner tape and try recording again.
Oct 23, 2007 | Sony Handycam DCR-TRV340 Digital Camcorder
Sony Handycam DCR-TRV340 Digital Camcorder Logo
1,132 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
