Question about Dishwashers
I have a Blanco DWF6XP dishwasher. I made the mistake of turning it off with the on/off button just after the wash cycle had started. Now there is no lights showing and nothing happening.
    Problem Solver:
  • 17 Answers
Wait 30 min and try again.to start it
Posted on Dec 23, 2016
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 21 Answers
Posted on Dec 22, 2016
Testimonial: "Thanks Eric. A slightly different model to mine but I will try to find the manual for mine."
Indesit DIF04UK: Help with problem determination please?
Modifying a wash cycle in progress:
If a mistake was made during the wash cycle selection process it is possible to change the cycle, provided that it has only just begun: open the door, taking care to avoid the escaping steam, and press and hold the ON/OFF button; the machine will switch off with a long beep. Switch the machine back on using the ON/OFF button and select the new wash cycle using the SELECT WASH CYCLE button; start the cycle by closing the door.
Dado
Sep 08, 2014 | Indesit Dishwashers
Whirlpool adp 4404 5 - how to do a RESET?
It is probably stuck in the dry cycle.
Press and hold the start button to clear it.
You should hear it pump put while it resets from memory.
May 27, 2014 | Dishwashers
Blanco dishwasher
Dishwashers do not usually complete the cycle if the water temperature is not adequate for the wash program selected. This could be due to inlet hot water not at correct temperature if dishwasher uses hot water or the heater or thermostat within dishwasher being faulty and not able to heat the inlet cold water to the right temperature. Try to run the dishwasher with the rinse or quick wash (low temperature) setting and see if it completes. Might help if you post the Model number in the comments field.
Apr 22, 2014 | Dishwashers
Blanco bfdwc61ss dishwasher wont finish washing in any cycle...its doesnt stop, just keeps going and going...it went all night without stopping and the dial didnt move...can you advise what to do??
please see the causes and fix it: God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Jul 21, 2012 | Dishwashers
Blanco dishwasher error d06 faulty motor.
I have a Blanco BFD10X Dishwasher which had the same D06 error, being a Electrician i investigated the fault which Blanco report as motor over current. After testing the motor, i tested the motor Run capacitor and found it to be faulty, these capacitors are common to failure and will cause the pump to draw more current than usual.
A genuine replacement 2.5uf capacitor was quoted at $120.00, however i purchased a equivalent from RS online for $14.30 + delivery. RS P/N 769-4267
Dishwasher working fine again.
Nov 15, 2011 | Dishwashers
I have a brand new Blanco dishwasher but im unsure if it is a DWF6XP, DWF4X or DWIN7 model. It does not have a salt dispenser if that helps. Last night when running for the first time i had a plumbing...
Unplug it and wait 5 minutes. Plug it back in. This will reset the machine. Put it on full cycle and allow it to do a full cycle. It should work just fine.
Nov 16, 2010 | Dishwashers
My blanco bfdw6x dishwasher has the folowing symptoms - power on, 30 min wash cycle set, after pressing start cycle button the machine sound likes it tries to start, but then cuts out and the digital...
Ours does the exact same thing. We pull it out and tip it which drains some water on the floor and then it works. It is something a technician told us ages ago, something to do with a water level switch underneath.....but its driving us mad. We have to do it on a regular basis. Does anyone know how this can be fixed more permanently. thanks.
Sep 03, 2010 | Dishwashers
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
