Question about Garden
The trimmer runs fine but once its hot it does not want to run
  • 130 Answers
Rings are going bad this is what happens when ring start going bad get hot and clyiner expaines more than the rings.you might whant to buy a new one.let me know.you can try change sparkplug sometimes when sparkplug gets hot it will try to quit firing so try that first.ok let me know
Posted on Jul 22, 2009
Starts but cuts off when engine gets hot
when it first dies check for spark or even better get a inline spark tester
Apr 06, 2012 | Garden
My Ryobi start great but when I change it from start to run stays few seconds and died
  • Alow the engine to run for longer on the start setting before you switch to run
  • Ensure air filter is clean. Foam elements can be washed with hot water and detergent. Paper elements can be cleaned with compressed air blown from the inside of the filter but ideally should be replaced.
  • Check fuel lines aren't kinked or blocked restricting fuel flow.
  • Ensure fuel filter isn't dirty. This is probably located at the end of the fuel line in the tank.
  • The fuel lines may have become airlocked.This can happen if the tank is run dry. If the trimmer has a primer bulb, alternatively press it several times and then try to pull start the engine with choke on. Repeat this several times. The primer bulb should feel spongy and fill with fuel.Once the engine kicks, switch to run.
Apr 05, 2011 | Ryobi Gas Hedge Trimmer
Husqvarna SRM 225 It starts fine but dies once you give it gas.
I was having the same issue with my 128LD string trimmer. I called a local Husqvarna service dealer and they told me the issue was a result of the ethanol in the gas. They suggested I find ethanol-free gas (aka 'Pure Gas') and try it. [http://www.pure-gas.org/ was the best resource I could find for this]
After disposing of my old gas and filling the trimmer with premium grade, ethanol-free gas (with Husqvarna brand oil mix) and applying 3 squirts of carburetor cleaner to the carb, it runs radically better.
I hope that helps you too. I know how frustrating that can be.
Jul 21, 2010 | Husqvarna 225cc Hedge Trimmer 22" Cut HVH...
Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Sep 20, 2009 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Ryobi EX26 dies when hot, won't start, then when cool starts
This sounnds too good to be true, but believe it!
The next time you run the trimmer and it starts to die, loosen the gas cap. It should start to run again. This means that the gas cap is clogged. Either clear the gas cap or buy a new one. This should solve the problem.
If you need further assistance, just let me know.
Jim
Jun 30, 2009 | Ryobi 15" Electric Factory Reconditioned...
Hard starting will not restart after warmup
Try this: The next time you run the trimmer, and it begins to die, loosen the gas cap. It should start running again. This means that the gas cap is clogged. Clean the holes out of gas cap, or buy a new one. (If this doesn't help, give a more detailed explanation the next time.)
Jim
Jun 05, 2009 | Husqvarna 28cc Gas Line Trimmer
Engine runs but no power to the head
It could be simple. Sounds like the drive cable came loose or broke. You could get an estimate from a repair shop -- probably not terribly expensive.
May 08, 2009 | Garden
Troy-Bilt Trimmer TB425CS
Sound like the clutch is going out or already is bad. There should be a cone shape cover that attaches the engine to the handle. Usually with 4 screws. Take those screws out and seperate the housing. There is a small centrifugal clutch, which is probably bad.
Jan 20, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Garden Logo
128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
