2003 Saab 9-3 Logo
Avril L'Mour Weathers Posted on Dec 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which fuse disarms the theft alarm system on a 2003 Saab 9-3 convertable?
The service theft alarm message stays on and interferes with the starting system. I want to disengage the alarm.
Lawrence Oravetz
Level 3:
  • Saab Master 10,558 Answers
  • Posted on Dec 22, 2016
Lawrence Oravetz
Saab Master
Level 3:
Answers
10558
Questions
Helped
2700297
Points
29284
Taking out the alarm fuse will cause the engine to never start. Try locking and unlocking the driver's door with the key to see if it resets. If not then service the alarm system.
Testimonial: "Thanks, I will most certainly try that first. I also discovered that locating the Theft Security Alarm under the left wheel arch and removing it altogether (or simply disconnecting it) avoids the start problem altogether and kills the annoying siren's meaningless deployment as it's battery dies. Servicing the alarm system is not my best investment option, but check this out -> https://youtu.be/NiHcd-8h6JY"
2answers
What fuse would disarm my alarm on a 2003 GMC sierra
None of them! That's not the way the alarm and anti-theft immobilizer works. This explains.
https://www.fixya.com/cars/r29887709-gm_passlock_security_system
How to reinstall key ignition in 2003 KIA Sedona
Disarm anti theft device
Google or Bing it. Lots of blogs about disarming or disabling security systems. Is this a factory installed alarm? You will have to pick carefully, but there may be a saab story out there!
Prepare for a big learning curve. I'm happily too old to learn, but it looks like a lot of wiring there.
I have Saab 2008 9-5.theft alarm comes on aftir 60.sec.if i lock the car in deadlock.anyone??
Try to remove and put back on no17's fuse in dashboard...
Hope it will help you, even if my english isn't terrible....
New saabgirl.
Replaced the alternator, now anti theft won't disable
The ignition lock anti-theft switch (19A438) detects if the ignition key cylinder is broken or "slam pulled" during a theft. The ignition lock anti-theft switch is always monitored by the remote anti-theft personality (RAP) module. This allows the alarm system to be triggered in the case that the ignition lock anti-theft switch detects tampering of the ignition key cylinder (even in the event that the alarm is not active at the time).
Refer to the Section 501-14B for more details on the keyless entry remote transmitter (15K601).
The door open warning lamp switch (14018) communicates to the RAP module through the generic electronic module (GEM). This input to the RAP will cause the anti-theft alarm to be sounded if the anti-theft alarm was armed.
The door disarm switches are assembled into both LH and RH lock sets. The door disarm switch must be triggered before the mechanical lock unlocks. This is to prevent the anti-theft alarm from activating when it should have been disarmed.
The RAP module controls the anti-theft system and is the brains of the keyless entry system. The RAP module communicates with the GEM to request that the interior lights be turned ON/OFF with use of the keyless entry remote transmitter, and the GEM communicates to the RAP to inform when the door is opened. Refer to Section 418-00 for inter-module communication.
The RAP module has three wire connectors attached to it:
  • The antenna for the keyless entry remote transmitter.
  • 26 circuit connector (C256).
  • 22 circuit connector (C257).
In addition to the perimeter alarm that uses the door open warning lamp switch, the RAP module also uses the ignition lock anti-theft switch and the autolock/relock feature to prevent theft of the vehicle. For a full description of the autolock/relock system, refer to Section 501-14B .
The THEFT LED is found on the instrument panel between the tachometer scale and the needle pivot point. The LED is illuminated during prearming and flashes when armed or triggered.
Prearming and Arming the System
The system can be armed if:
  • The ignition is OFF.
  • The PANIC alarm is OFF.
  • All doors are closed.
There are two ways to prearm the system:
  • Press the LOCK button on the transmitter.
  • Open a door, press the power door lock button and close the door.
After 30 seconds the system will be armed and the theft indicator in the cluster will flash every two seconds.
Disarming an Untriggered System
An armed system will be disarmed with one of these valid actions:
  1. Pressing the UNLOCK button on the transmitter.
  1. Placing a key in the door and turning to UNLOCK.
  1. Turning the key to RUN or ACC.
The anti-theft alarm can be triggered by the following conditions:
  • The ignition cylinder is damaged with or without the RAP being armed.
  • A door is opened without disarming the armed RAP module.
The remote transmitter can activate a panic alarm which is similar to an anti-theft alarm, but does not deactivate the starter or cause the theft indicator to flash.
Disarming a Triggered System
If the system has been triggered, (the horn honks, the lights flash, and an external starter interrupt relay is engaged), the system can be disarmed by:
  1. Pressing the UNLOCK or PANIC button on the transmitter.
  1. Putting a key in the door and unlocking the door.
  1. Turning the ignition to RUN/ACC (Turning the key to RUN/ACC will not disarm an alarm that has been triggered by the ignition lock anti-theft switch.).
2helpful
Saab 2004 9-3 Convertible
Had same problem, in the boot right hand side, behind the removable panel there is :
1 - a hydraulic reservoir which must be at correct level.
2 - a black box (stc) this controls the roof system,
switch ignition off then pull the 2 connectors off for 30sec then reconnect.
This worked and hope this resolves your problem
6helpful
4answers
Theft Alarm goes off every 60 seconds
In order to disarm the alarm system, you need a tech 2 computer (usually Saab indy repair shops or Saab dealers only will have this very expensive computer and the flash cards needed) in order to change the programming in the TWICE theft alarm computer so the vehicle thinks it is not equipped with an alarm system. Two other more expensive options are replacing the entire module, or cutting the module open and replacing the internal batteries.
Justin Duthie
Strictly Saab
Melbourne, FL
6helpful
2answers
Theft alarm sounds w/o provocation
This sometimes can also be related to the internal batteries in the alarm ECU or alarm siren module going bad. If your handy the internal batteries can be replaced without buying a new replacement unit. Otherwise, the entire module must be replaced ($$$). Lastly, you can have a Saab indy or dealer disarm the theft alarm on the vehicle. You retain your keyless operation, but the alarm is not active. This is done in the programming and adjustment menus in the TWICE unit with the Saab Tech 2 computer.
Justin Duthie
Strictly Saab
Melbourne, FL
Top Saab Experts
ZJ Limited
ZJ Limited
john h
Sean Wright
Sean Wright
Are you a Saab Expert? Answer questions, earn points and help others
