Question about Microwave Ovens
Gaggenau microwave BMP225110 - error code E138 comes up after only a few seconds of the microwave seeming to work then it stops. Any idea what is wrong and how to fix it pls?
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave quit
I would suspect either door switches or an intermittent control circuit board, either of which can be repaired. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure over time. I have a text file on my site called "doorsw.txt" which helps in diagnosing and repairing door switch problems. You can find the file via a Google search. It will help you check and replace the door switches if you or an able friend is so inclined. In some cases, the problem is a bad connection or a bad relay on the control board. That's something we see fairly often, and we repair them for only $32.50 nationwide.
Posted on Oct 12, 2006
MicrowaveSvc
  • 9085 Answers
SOURCE: F-9 error on LG microwave
This is a problem with the inverter or magnetron. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. You can find support for service or parts at http://us.lge.com/support/support.jsp
Posted on Sep 22, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: kenmore elite utra microwave 721.63763300
Your model number prefix of 721 means it's made by LG / Goldstar.
F9 code on an LG means either a bad door switch or a loose door switch mount.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://www3.sears.com (the 3 is correct)
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 20, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave error code
EE4 means the line voltage is too high. Usually this is fixed by resetting the voltage selector on the back.
The voltage selector may not look like a switch, looking rather like a metal panel that has to be taken off and reoriented. There will be a label next to it indicating a voltage number.
EE2 actually means that the control circuit senses that magnetron number 2 is not running.
It doesn't necessarily mean a bad magnetron.
This can be due to a bad or misaligned door switch (common), a failed relay (#3) on the control panel, or a failed high voltage component such as transformer #2, capacitor #2, rectifier #2 or magnetron #2 or loose connections anywhere along the chain.
We have a similar model's service manual on our site. Please not that yours may be different! Part numbers will probably not match. But it will help with safety, disassembly, discharge and diagnosis.
It's here: http://www.microwavedisplay.com/r23gtf_sm.pdf
Posted on Apr 01, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Will run for about 18 seconds,then gives an F7 error code
>No, the service guy did none of the things you suggested.
Just as I suspected...
The "element" as it is so inaptly misnamed in the case of this warranty document, is actually the "magnetron", which should normally have an extended warranty beyond the normal 1-year (I assume) parts and labor warranty anyway.
The magnetron may be the culprit here, but a thorough check of the points on my previously posted list is in order to determine the actual cause of the problem.
Since your husband is an engineer, I would suggest that he invite a colleague over to help and to provide some backup for any heavy lifting if it should need to be removed from the wall.
Safety first after all!
You can download Kitchenaid Whirlpool owner's manuals and installation instructions here in case it needs to be taken down during troubleshooting.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 15, 2008
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
Jan 24, 2015 | Panasonic Microwave Ovens
Samsung microwave se error
see the video attached. God bless you
Dec 09, 2013 | Samsung MS1040BB Microwave Oven
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Samsung microwave SMH8165W displaying error code -SE- and continuously beeps.
SE means system error, the keypad has a short in the membrane, or the control board has issues.
Jun 14, 2012 | Samsung SMH8165W Microwave Oven
I have a Panasonic Dimension 4 Microwave/Convection "The Genius". The microwave stopped working? Can you advise?
So we can help you, please post a NEW FixYa inquiry which includes your full model number from the tag on the unit, and the answer to these questions:
Is it dead? (meaning no display, no beeps when you press a pad on the keypad and the inside light does not come on when you open the door)
Is it running but not heating?
Any usual noises?
Does it shut off after a few seconds when you try to cook with it?
Of so, exactly how many seconds?
Are there any error codes on the display?
Also, if you;re not in the US, which country are you in?
Oct 11, 2009 | Panasonic Microwave Ovens
Sharp R-9h91B microwave oven stopped working
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Sep 28, 2008 | Microwave Ovens
Neff 5474.0/gb. When microwave time and power is set, after pressing the start button,the microwave works for about 2 seconds then stops and the fan starts. the error code H 95 shows on display. The...
After a bit of digging, it appears to be an issue with the door not being closed correctly (or at least the it thinks is isn't.
Ref:http://www.sampfordixl.com.au/gaggenau/upload/BM221130_instr.pdf
I know its a different model but the functionality is identical...
Apr 27, 2008 | Microwave Ovens
Microwave works for a few seconds and then the lights and turn table inside shuts off.
hi the light and turntable work of a common relay located on main pc board.relay probably dry jointed or sticky or check switches behind door catches
Feb 27, 2007 | Maytag MMV5000 Microwave Oven
Microwave Ovens Logo
103 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
