I just got an invision monitor. I plugged it into my xbox but it would only say, no signal. I started fidgeting with the buttons, until it says BURN IN and its flashing colors.
If you could tell me how to 1. take it out of burn in mode and 2. how to connect it to my xbox. The monitor has no hdmi cord so I rigged it up through a vga to hdmi converter. Also IMPORTANT it only has 4 buttons, one that says 1 one that says 2 one that is an up arrow and one that is a down arrow. PLEASE HELP!
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
SOURCE: Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Posted on Aug 13, 2008
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
  • 814 Answers
SOURCE: seem to have locked the monitor in burn in mode
This problem is a failure of the control circuit of the logic section of the monitor. The control circuit has latched on this function due to failure of some component or the control itself.This problem requires you to return the unit for service at the dealer or take to service center. Hope this helps.
Posted on Apr 14, 2009
SOURCE: Monitor Flashes Colors when system powered down
Reset factory settings. Push the selection button (second button from the left at the bottom of the monitor, next to the AUTO button), then go the the Factory Reset by pressing the minus button. Press the selection button again, and when it asks if you want to reset say YES by using the minus button. It's a quick fix!
Posted on Apr 29, 2009
What do i do when the dialogue box reads 'cable disconnected burn in mode'
Get monitor out of burn in mode by unplugging the power to monitor then while holding down the power button on monitor plugged in the power cord to the monitor all while it is connected to a running computer. Turn the monitor off with the power button. When press the power again the burn in mode should be gone and the monitor should display the computer
Apr 24, 2015 | Sony SDM-HS73P 17" LCD Monitor
No input signal VGA/Xbox
You are doing nothing wrong. The best thing to do, which you are doing, is to eliminate possible problems. Try a different cable, monitor etc until you narrow the problem down to a single component.
Aug 05, 2012 | Microsoft Xbox 360 Console
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
http://support.xbox.com/en-us/pages/xbox-360/how-to/audio-video-devices/connect-xbox-360-console-tv.aspx
and for the video reset about halfway down the page:
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/xbox-360-top-issues/tv-or-monitor-screen-is-blank-while-connected.aspx
Mar 30, 2011 | Video Game Consoles & Games
No HDMI Signal from my PS3 and it works on other monitors. Help?
I'm guessing it's the PS3.
When you turn on the PS3, HOLD down your finger on the power button (the one that turns it on/off, NOT the switch in the back) until you hear a second beep while the console is turning on.
It will completely reset your display settings. I have an HDTV and a HDMI, and whenever I switch from one to the other I HAVE to do this or I get no video on screen.
Mar 07, 2010 | Acer H233H bmid Monitor
I have a compaq s910 monitor when not plugged in to my computer
you may need to hard boot your computer (hold down the power button until it shuts off and then turn it back on). otherwise, look for an input button your monitor.
Jul 11, 2009 | Compaq S 910 Monitor
AOC Monitor says "no signal" and won't wake up!
This monitor refuses to wake up because it cannot find the signal from the computer.
When the light is amber, force the pc to shut down by holding the power button until all lights go off. Then, after about 10 seconds, power the pc back up again.
If this does not start your monitor, unplug all the monitors connections and plug them back in again. These things should reform the connection from the pc to the monitor.
good luck
tony
May 18, 2009 | Computers & Internet
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Oct 07, 2008 | Sceptre DCL9a
Benq monitor flashes primary colours when switch on or off
This is called burn-in mode. Used to test the monitor at the factory.
To fix this, use the buttons under the front of the monitor,
There are six buttons. Let's number them 1 to 6 from the left.
Press 6 to display menu (at the bottom in Red will say Burn in mode on)
Press 4 or 5 until Recall is highlighted
Press 6 to select
Press 4 or 5 until Recall All is highlighted
Press 6 to select
Press 4 or 5 until Yes is highlighted
Press 6 to select
Press 3 to exit
This will reset all paramaters and also turn-off burn-in mode
If you want to reset some parameters to your preferences, press 6 again to bring up menu and
see you user guide to get explanations for the different settings.
Dec 10, 2007 | BenQ FP71E 17" LCD Monitor
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
