Question about Invicta Watches
Invicta 10621, Invicta 1538, Invicta 0077. What the battery size for each of these Invicta watches?
  • Stephen Dec 22, 2016
    Thank you for pointing out the obvious. I'm asking before I open them up. His way I can save time Incase some of the watches use the same battery.
    Top Expert:
  • Invicta Master
  • 45,115 Answers
Open them up, find the battery holder, and identify type.
Posted on Dec 22, 2016
4 Suggested Answers
SOURCE: Invicta 2875 wrist watch band too large
http://www.geocities.com/watch_crazy/bands/bands.htm
Posted on Jun 30, 2008
escapement
  • 2334 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
  • 43 Answers
SOURCE: What size battery goes into invicta watch model 4899
Old one has a number on it.
Posted on Jun 09, 2014
Whats size battery for invicta lupad 21495
Take your Invicta watch to a jeweler who will demonstrate how to open it without damage, identify the battery type, and may even replace it for a modest sum.
May 03, 2018 | Invicta Watches
What size battery for 21813 Invicta bolt Zeus’s
Take your Invicta watch to a jeweler for identification of the battery type and possible replacement.
Apr 16, 2018 | Invicta Watches
How to open invicta 1792 to replace battery what size battery does it use
Take your watch to a jeweler who will demonstrate how to open it, identify the battery type, and perhaps replace it for a reasonable sum.
Jan 09, 2018 | Invicta Watches
What size watch battery does a Invicta sub aqua 1v take
Take your watch to a jeweler who will identify the battery type and perhaps replace it for a reasonable sum.
Jan 06, 2018 | Invicta Watches
What size battery dies my sub aqua noma Invicta watch take
To find battery type, take your Invicta watch to a jeweler.
Sep 25, 2017 | Invicta Watches
What size battery does an invicta reserve model 12018 take
Take your watch to a jeweler who will identify the type (not size) and may even replace it for a nominal sum.
Dec 23, 2016 | Invicta Watches
What size battery for invicta model 12843?
  • Remove back
  • Find battery
  • Identify type
OR,
Take your watch to a jeweler who, for a reasonable sum, will replace the battery.
Nov 28, 2016 | Invicta Watches
What battery size takes the Invicta Cuadro 14700
The battery described for this watch is 'non-standard'. I would take it into a jeweller.
Invicta Men 14698 Cuadro Analog Display Swiss Quartz Two Tone Watch
Oct 29, 2015 | Invicta Watches
Watches Logo
188 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you an Invicta Watch Expert? Answer questions, earn points and help others
