Question about LG Refrigerators
LG refrigerator LRBC22544ST has a small snake shaped plastic bottle behind the crisper that has a crack and is leaking. What is that part called?
  • 159 Answers
SOURCE: Problem with water flow in LG LRBC22544 Bottom Freezer Refrigerator
Sounds like you have excess pressure building up in the water system. Is the water dispensor working? If not it sounds like you have a frozen line somewhere or the valve in the door is not working to allow the water to dispence.
Posted on Jul 13, 2007
  • 90 Answers
SOURCE: Whirlpool semi defrost refrigerator
Best to call for help.
Posted on Jan 17, 2008
SOURCE: Leaking Whirlpool refrigerator
My Whirlpool fridge had water droplets falling onto all three shelves and pooling unter the crisper drawers. I solved the problem by clearing the ice-clogged drain in the freezer.
In Whirlpool model ET21UM, the condensation drain hole is located directly behind the freezer. To access the drain hole, remove all your frozen items and place them in a large picnic cooler. Notice that the floor of the freezer is basically a large plastic tray fastened by two small bolts. Unscrew the bolts with a wrench or ratchet and remove the plastic tray. At this point you will probably see that water has seeped under the tray and created a mini ice rink on the bottom of your freezer. You can tap the ice lightly with the handle of a screwdriver to break it up. Once it's broken, toss the ice into your sink, or put it in a plastic bag and store into your cooler to keep everything cold.
Once the ice has been removed from the freezer floor, you should be able to see a metal drip trough in the back under a false wall hiding the condenser coils. It's a little tougher to remove the ice from the drip trough with the screwdriver method, so you might want to use a hair dryer. After a few minutes with the hair dryer, you should be able to remove most of the ice by hand. You can remove any water with a sponge or turkey baster. The only ice left will be a plug of ice in the drain hole in the middle of the drip trough. Heat up a cup of water in the microwave and carefully pour it into the drip trough. If the drip trough is hard to access, you might need to use a funnel. The hot water should melt most of the ice in the drain hole. If it pools in the drip trough and doesn't drain, use a sponge or turkey baster to remove the water and add hot water again. A small length of wire or a pipe cleaner might help clear any other obstruction in the drain hole. When the drain is clear you should hear water flowing through it. Dry off the floor of the freezer and return the plastic floor tray to it's spot and fasten with the two bolts. Remove any water that has pooled in your refigerator and you're done.
Posted on Nov 12, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Whirlpool Refrigerator(side by side) leaking water
First question would be is your ice machine leaking? If so then disable the ice machine until we can find the cause of leaks and repair them. Is the freezer freezing well? Food compartment temps OK?. Let me know and I will work to help you resolve this. Sea Breeze sea breezehvac@yahoo.com
visit my site below
http://servicepartstec.blogspot.com/
Posted on Mar 30, 2009
heatman101
  • 43501 Answers
SOURCE: Water under crisper drawers and then leaking outside underneath.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 02, 2010
How do i fix a crack in my radiator in my 1996 chevrolet cavalier
Is your radiator Plastic and metal? or Just metal? where is the crack? Can you see the "crack" or can you just see it leaking antifreze? It could be a hose clamp leak,or small hole? At this point without knowing that it is a crack for sure ,all I can say is check hose clamps ,they also sell a product called Bars . Any auto parts store has ,it seals small radiator leaks ,be sure to follow directions on bottle! I would recommend changing the raditor if your keeping the car,or really depend
on it,they like to go bad at the worst possible times!
Feb 10, 2012 | Cars & Trucks
Water is leaking onto the inside floor of the fridge. when u used the water dispenser it leaks even more
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
May 12, 2010 | Refrigerators
I have an LG fridge (LG LRBC22544) that collects water underneath the crispers. It freezes (almost 1 inch thick) and then melts. Once it melts, then it leaks out the door. This reforms every 3 weeks or...
I have had the same problem. In my case, its the little water tank behind the left crisper. The tank has cracked (twice now) which means replacement (again). The water leakage gets so bad that it leaks into the freezer causing ice up problems in the rear.
Apr 27, 2010 | LG LRBC22544 Bottom Freezer Refrigerator
My freezer seems to be accumulating water under the drawer. it is coming from the back wall on the right, but there is no leak anywhere else. I do not have an automatic icemaker installed. What could be...
Plastic water bottles on upper shelves sometimes have small leaks. Remove all above water containers. Maybe you spill some water replacing ice trays? Identify the source of water..that will be the cause of problem.
Feb 16, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Our LG LFX25950SB has been freezing all the food in the refer since we purchased it 3 years ago. Had numerous service calls. They tell us we are leaving the door open, we do not have the correct...
Contact LG @ 1 800-243-0000 and let them know what is going on.
This is a known problem and a fix is availiable.
LG may help you out.
Call M-F for the american call center to answer.
If they wont you can fix it real easy.
Pull out bottom crisper dware.
Look on the back wall.
You will see a dime sized hole.
This hole allows cold air from the freezer to cool the crispers.
Cover the hole with a small piece of duct tape.
This should stop the crispers from freezing.
Also on the right wall of the ref. you will see 1 or 2 egg shapped white covers.
Remove the covers carefully so you dont break it.
You will see a 1" white thermister probe.
Pull the probe out of the insulation and clip it on the egg shaped cover and reinstall the cover.
The thermister tells the computer how cold the ref. is.
Jan 12, 2010 | LG LFX25960 Titanium Bottom Freezer French...
My refrigerator started leaking underneath on the right back side. Can you tell me what is wrong and what needs to be done?
If you have icemaker in your fridge - remove cover on the back and down and check the plastic water tubing for cracks and loose connections.
If nothing found or you don't have icemaker - there is a drain pan on the bottom, behind the same back cover. Check if it has any cracks or tilted. Check if the drain tube is routed to the drain pan and is securely attached to the drain port on the bottom of the fridge.
Oct 12, 2009 | GE Â 17.9 Cu. Ft. Top-Freezer...
Cracked border to bottom shelf of frigidare refrigerator
240350614 is the part number for the shelf border that you need...price is around $26
Oct 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
Feb 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Water in the bottom of the refrig
HI thanks for your question. the drain tube is clogged. to repair turn fridge off, for at least 24 hrs. as the frain tube is between the inside and outside wall. so its just not dirt in the drain tube, its frozen . to clear after 24 hrs . purchase a small plastic tube , go to the drain tray at the back shove the small hose up the drain hose and blow air up the tube . it will unclog. thanks the appliance doc. please rate my answer. thanks.
Sep 22, 2007 | Amana ATB2135HR Top Freezer Refrigerator
Water leaking from dispenser into refigerator/French door bottom freezer
IT IS PROBERLY THE HOLDING TANK / TUBES LEAKING TAKE LOWER CRISPERS OUT AND CHECK THERE ITS BEHIND THEM
Aug 26, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
Refrigerators Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
