Question about Kenwood EW7507EK Oil Radiator
EW7507EK. Can anyone tell me what color wires go onto F-3, F-4, F-5 of the circuit board? I feel like an silly for not taking a photo before starting the repair
I have a Midland VHF Marine radio mod 78-100 and I have lost the three pin power cord. anyone know the +/- configuration within the existing pin setup so that I can make another?? The cord is NLA.
I quickly checked the net for available diagrams and didn't find one for your radio. If you feel comfortable simply remove housing from the radio and check color of the wires and markings where those wires are connected to circuit board.
Feb 02, 2018 | Midland Boating
Tip
Wiring For Volume and Power Switch
I ripped the cord off the external thing-a-ma-bob for the volume and power switch on the Maxell Flat Speakers with Subwoofer unit, but managed to figure out which color wires attach to each numbered contact on the small circuit board inside the unit. The board has labeled contacts from 1 through 9, and following is the map for each color wire:
1 = Black (large wire, ground)  2 = Red 3 = Brown 4 = Orange 5 = Yellow 6 = Green 7 = Blue 8 = White 9 = Black (small wire)
I resoldered each wire back to the little board and it works like new. Much better than throwing them out and getting new ones, because these speakers have a decent sound and take up very little room.
I hope this helps anyone who runs into the same situation, because I was unable to find this information anywhere else and had to figure it out by trial and error.
on Sep 04, 2008 | Maxell Flat Speakers With Subwoofer and...
Kenwood Electric Oil Heater. Model EW7507EK. Can anyone tell me what color order of wires onto the circuit board? I feel like an silly for not taking a photo before starting the repair. F3-5
Look carefully on the board itself. Sometimes the wire color codes are labeled right next to the connector. If not, there may be some other letter codes and these should match the ones on the thermostat.
Dec 22, 2016 | Kenwood EW7507EK Oil Radiator
The black wire in the cable to connect in the wall is disconnected in the circuits board where it is suppose to be connected?
I doubt anyone can give you a useful advice simply as only reference a "black wire".
Take some good photos of your board and post them, maybe seeing the problem someone can help you.
Jul 16, 2015 | Pool & Spa
Wont turn on, makes buzzing noise
FIXED
I have a deal with this kind corporates sabotaging for 2-3 times a month fixing computers and monitors.
The circuit boards for many BRAND NEW household devices, PCs, Computer monitors, dehumidifiers etc. purposely designed to work a little bit after warranty period and die quietly
Heater EW7507EK fixing. (soldering required)
Step 1. Turn it over. Unscrew 2 screws on the bottom of the face side.
Step 2. Mark and Unplug 3 wires from heating element. Unscrew the metal cover from circuit board. Immediately you'll see small black cylinder (CAPACITOR 470mF x 35V). Retail cost about $1- $3
Check this - the top of this capacitor rounded, not flat. That is mean it was "quietly blowup" and electrolyte evaporate.
Ely
Boston
Dec 16, 2012 | Kenwood EW7507EK Oil Radiator
I have a delonghi des 14 dehumidifier. Usually it goes into pause mode for 3 mins when you first turn it on with the yellow light on and then starts dehumidifieing.It now stays in the pause mode forever...
Just fixed this problem with my DES14. Its a fault with the circuit board inside the machine and is very easy to fix, even for a novice. Here is how to do it:
1) Open up the machine by removing the screws in the case. (Make sure it is unplugged!)
2) Locate the circuit board on the side of the unit.
3) At this point you have two options. If you want a unit with full functionality you need to buy a replacement circuit board. I found one on MasterSpares (http://www.mastersparesonline.com/product/index/10147) It costs about 30 pounds. Simply remove the old board and replace it.
4) If you want a working unit for no extra cost (but without the functionality of the humidistat) then remove the rectangular white connector from the circuit board which has red,blue,white and yellow wires entering it. Add an extra wire between the central white wire and the red wire that is adjacent to the yellow. (see photo).
5) Re-assemble the unit. If you have opted for the free option the unit will work when you plug it in and switch it on but will no longer cut in and out with different humidities (or have the annoying warm up period). Thankfully the water overflow cut-out will still work.
Hope it works for you! Feel free to ask if you are confused!
Nov 13, 2012 | Dehumidifiers
Kenwood heater will not turn on when plugged in
FIXED
Step 1. Unscrew 2 screws on the bottom of the face side.
Step 3. solder new capacitor.
Enjoy
Ely
Boston
Nov 03, 2012 | Kenwood EW7507EK Oil Radiator
Electronic circuit diagram for a bass collection bass guitar Japanese 1988
I understand your pain - was googling for similar, and came across this post, 5 years prior. My SGC Nanyo Bass Collection has just started to play silly beggars with the pots, and a bridge fault. Nowhere online seemed to have any details of the wiring, as the problem is, as you say, the fact that all of the tone and volume pots are based on a printed circuit board. If theres a nick or short on the board, its a pig to replace, and I really wouldn't like to have to wire any pots onto it. I'm currently looking at the options of ripping out the old electrics and wiring it from scratch myself. If you're still after answers, good luck!
PS - noted that none of the previous replies are relevant to this - mostly going on about the amps or a Fender guitar??!
May 07, 2012 | Music
Kenwood EW7507EK Oil Radiator Logo
27 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
