Question about Dryers
Ceiling fan and light kit installation 4 wires 3/1 (red, black, white) from electrical box to 3 wire (black, white. green) from fan. How do the wires connect?
    New Friend:
  • 21 Answers
I'm assuming from your question the 4th wire in your electrical box is a bare copper wire which is the ground. The green wire gets wire-nutted to that. The white wires get wire-nutted together. I'm guessing you have two switches installed in the wall for the fan because there is a black and red wire coming from your electrical box (one for the light and one for the fan) connect the two black wires together. The red wire is then connected to the blue wire in the fan which is the light.
Posted on Dec 22, 2016
Black wire, white wire, and tan wire coming from ceiling. New fan has blue, black, white wire and green wire on the bracket how does it hook up
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
Nov 11, 2017 | Dryers
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Box in ceiling has black wire and white wire & the ceiling fan has white wire, black wire and red wire.
BEFORE YOU PERFORM ANY CONNECTIONS BE SURE THAT THE CORRECT CIRCUIT BREAKER FOR THE BOX HAS BEEN TURNED OFF! You must check for voltage between the white and black wires at the ceiling box with each of your two wall switches toggled up or down ONE AT A TIME!
The green wire in the ceiling box (or bare copper wire) is your ground wire and should be connected to the green wire of the fan, and also should be mechanically connected to the electrical box by a screw or clip. If your system was wired correctly you should find that it already is connected to the box.
The white wire in the ceiling box is your neutral wire, so any and all white wires from the fan should be connected to it. You may have one for the fan motor and one for the light kit if there are two separate whites from the fan. Again, they may already be connected together in the fan/light assembly.
The black wire in the ceiling box is switched on and off from either of the two switches in the room, which I assume are located near two different doors to the room. These are called "three-way switches". They are not marked "on" and "off" on the toggle like any single-light switches in your home. That is why you must check for power at the ceiling box with the switches in each position one at a time to make sure that the circuit is de-energized.
Now for the connections:
You will need to connect both the red and black wires from the fan to the black wire from the electrical box. The black wire in your ceiling box is your "hot" wire and will provide power to both the fan motor (black wire) and to the light through the red wire--(sometimes this wire is blue, for others who are following this post).
With this arrangement, your fan and light will only operate with one or the other of your three-way switches completing the circuit from your breaker box. You will have to use the pull chains on the fan to control the fan and lights. So you will probably want to leave the light "pulled on" so that you can control the room lighting from either of your three-way switches, and operate your fan speeds from the pull chain. However, if you want your fan only on at night you will have to "pull off" the fan's light switch.
You may find all this switch flipping and chain pulling an inconvenience. If so, hire an electrician to install wiring so that the ceiling box will be "hot" all the time to the fan's black wire and the fan will therefore be operated by the pull chain only, and the light kit will be controlled by either of the three way switches, via the fan's red (or blue) wire.
One other caveat before you begin: you must make sure that the ceiling box is rated for and mounted sturdily so that it will support the weight of the fan and light kit. Many ceiling boxes are designed and mounted to support only a light-weight fixture. You don't want your fan to come crashing down from the ceiling!
Oct 15, 2012 | Hunter 52" Ceiling Fan With Light And...
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
Light only turns on with the remote. How do I set it to turn on with the wall switch?
There are some fan models (particularly with a remote control) that use multiple cycles of a single power switch to select the operating mode. For example, if you simply flip the switch on, you get the fan. If you flip it on, then off, then on again within one second, you get the light. If you flip the switch on - off - on - off - on, you get both. The trick is to do it fast enough so the internal power circuit doesn't run out of capacitor charge and forget what you're trying to get it to do.
Sep 28, 2011 | Hunter 52" Ceiling Fan With Light And...
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
Need to know how to wire this fan. Not using a remote or wall switch
Hello! W/D here.
In your ceiling box, you'll find 3 wires; black, white and bare copper.
In your fan, you'll see 4 wires; black (or red), white blue, and green.
With your breaker tripped, connect the green wire on the fan to the bare wire in the ceiling (this is your ground).
Connect the white fan wire to the white ceiling wire (this is your common).
Connect the blue and black (or red) together, and connect these to the black wire in the ceiling (this is the hot lead, and will supply power to the fan and the light).
Best regards, --W/D--
Feb 13, 2011 | Westinghouse 78500 Casanova White Ceiling...
Does the blue wires connect to the black or white wires? I cannot find the instruction booklet. Thanks
Hi, At the fan you'll have a black wire, blue wire, green wire and white wire.
In the ceiling you'll have a black wire, a white wire, and a bare copper wire. If you are using the same wall switch to turn on all of the power to the fan AND the light, connect as follows:
White at ceiling to white from fan
Black at ceiling to black and blue together from fan.
Bare copper wire at ceiling to green wire from fan.
When connected like this, the main power is from the switch, and the fan and light may be set by the pull switches on the fan.
Best regards, --W/D-- Please feel free to rate this solution... thanx!
Aug 03, 2009 | Casa Vieja Endeavor Cherry Ceiling Fan
Hampton bay Windward III
Green and copper are the ground wires and I believe you can connect both these to the green wire from the fan (I only have the copper wire in the actual ceiling box). Black and Red can be treated as both black and both can be connected to the black wire from the fan (this is what I did in all my fans and it worked). White is the neutral wire and can be connected to the white wire from the fan (this is what I did in all my fans and it worked).
My ceiling box has the copper, red, black, and white wires. The ceiling plate for the fan I bought had a green wire. I connected the green wire from the ceiling plate and the copper wire from the ceiling box to the green wire from the fan.
Dec 29, 2007 | Hampton Bay 52 In. Black Huntington III...
Wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Oct 20, 2007 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
Top Dryers Experts
