Question about Electrical Supplies
High altitude operation of a ryi2200 generator (5000 ft)
    Sergeant:
    Habit-Forming:
  • Electrical S... Expert
  • 156 Answers
You require a high altitude carb (or carb jet) to operate correctly at this altitude. The jets are smaller to compensate for the thin air.
You need to get in touch with Ryobi to see if they sell them.
Do not adjust anything else on the generator!!!!
Posted on Jan 03, 2017
3 Suggested Answers
  • 83 Answers
SOURCE: three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Posted on Apr 02, 2009
  • 61 Answers
SOURCE: I have an Ef3000iseb runs great here at or about 5000 ft. go up in the mountains it starts loading up and wont run. is there a higher altitude kit?
Yes thats true
there is high altitude re jetting in the carburator your carb has to be re jetted for the normal operation of the generator at high altitudes by the authorised personel but when you will bring it back again at the orignal altitude it will get heated quickly and may not function properly so you will have to bring the carb settings to its orignal position so be careful
Posted on Aug 12, 2012
Does the altitude of 4000 feet has affect on someone with low blood pressure?
I am not a doctor but I can tell you that at 4000 feet there is about 87% of the oxygen compared to sea level. High altitude is usually defined as 5000-11,000 feet. High altitude actually increases the body's blood pressure.
Dec 10, 2016 | Health & Beauty
Tip
?JCB FAULT CODES LIST
P0087 (flashing code 227) shared sump low pressure fault (for pump without pressure supply)
The main fault symptoms
• Engine severe vibration.
• idling unstable
• Output Fall
• exhaust smoke
• It may be too large output
P0088 (flashing code 118) shared the tank pressure is abnormally high (first or second stage)
• idle instability
• Output Fall
• channeling gas engine failure
• exhaust smoke
P0089 (flashing code 151) shared the tank pressure failure (for pump pressure supply is too large)
• idle instability
• Output Fall
• exhaust smoke
P0090 (flashing code 247) SCV drive system open, + B short circuit or shorted to ground
• Depending on the open / short situations, there may be an engine stall and / or launch
Machine channeling gas.
• exhaust smoke
• Output is too large
P0107 (flashing code 71) atmospheric pressure sensor circuit input low (open or shorted to ground)
Due to spare the equivalent altitude 2000 m (6562 ft)
• exhaust smoke at high altitude.
• insufficient output at low altitude
P0108 (flashing code 71) atmospheric pressure sensor circuit input high (+ 5V shorted)
• The high altitude exhaust smoke
• lack of low altitude output
P0112 (flashing code 22) intake air temperature sensor fault (low voltage fault, earth fault, short circuit)
• When cold starting, may exhaust white smoke.
More here http://truckmanual.weebly.com/jcb-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
What is the high altitude adjustment required by the manual?
the high speed adjustment needs to be richened up to compensate for the lean air mixture at high altitude. it can run but will run fast and may damage the unit because it is lean. the high speed adjustment is the one marked H or the screw farthest from the engine. turn it counter clockwise while running at full speed until it runs at the correct RPM. any small engine repair center should be able to do this for you and keep you from causing irreparable damage
Feb 27, 2013 | Toro 2-Cycle 25.4 cc Power Head 51944
Yes thats true
Aug 12, 2012 | Yamaha Ef3000iseb Generator Portable 3000...
It is not a problem like to know if i can use my coleman 5000 maxa er plus 10 hp. With A welder with out damage it. Tanks
Yes, you can use a welder with it. Pay attention to the ratings of the welder, don't exceed running watts of the generator. It would also be a good idea to try and use a welder that is less than the running watts rating of the generator. Then you would have some extra capacity to deal with fuel quality, maintenance history, momentary undervoltage, altitude, etc.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
Insufficient gas flow in furnace...could it be the altitude? we are at 5000 ft.
Yep, and as the temperature gets colder it will drop even more.
Dec 11, 2009 | Heating & Cooling
Installing high altitude kit on Cozy NG furnace
the orifice that comes with the unit has a starter hole only needs to be drilled out, in the instructions is a chart for altitude de-rating.
Oct 04, 2009 | Cozy Enclosed Front Console Heater 20,000...
I have a 1990 Wrangler with the 4.2L six carbureted engine. It is set up for under 4000 ft altitiude but I have moved to 5000 ft plus altitude. What do I need to do to set it up for the higher altitude? It...
Smaller jets in the carb, less oxygen in the air means, you got to have less fuel in the mixture otherwise wham to much nox and no pass the mans law...
Jun 12, 2009 | 1990 Jeep Wrangler
Humming noise
Most times a humming noise in a Plasma tv is associated with high altitude. If you live over 3500 ft. and when you first turn on the unit is has a slight buzz and it gets worse as it warms up then you have what is referred to as high altitude sickness. You shoul contact the manufacture with this problem and the should exchange the unit with one tested for proper operation at high altitude. If you do not live at high altitude then there is a problem in the unit that should be diagnosed.
Dec 18, 2007 | LG 50PX5D 50 in. Plasma HDTV
High color alteration on video capture on Sony DCR-HC42
your right it have to repair now cause the ccd image sensor is malfunctioning already...go to the service center for replacing the sensor...
Jun 12, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
