Question about Brother XL-3030 Electronic Sewing Machine
How do I replace the bobbin hook after cleaning my Brother XL-3030?
I removed the retaining ring and shuttle hook per instructions, but can't get it all put back together properly. The diagram in the manual is not helpful.
  • Brother Master
  • 11,494 Answers
You may be able to enlarge the manual page:
Brother XL 3030 User Manual Page 60
The hook (half-moon piece) needs to go in first, but you may need to wiggle it to seat it and then hold it while you fasten the outer retaining ring (hook race). Flip the levers up to hold the ring in place. Then install the bobbin case.
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
FWIW, my machine oiling instructions say to apply a drop of good quality oil on the outer edge of the hook race lip where the hook rubs as it turns. But, your manual should explain where to oil.
Posted on Dec 22, 2016
Bobbin trouble
Never use bobbins that are not made for your machine.
Possibility of further damage is high using parts meant for a different machine. Get the correct bobbins, clean the hook area where the bobbin thread is picked up. Use a tooth brush in and around the area where the bobbin fits.
San Diego, CA
Embroidery Services
May 08, 2014 | Brother XL-3030 Electronic Sewing Machine
Plastic shuttle not slotting into brother XL-2220
Look in your book or download one for the XL2230 (nearly the same as the XL2220) here:
Apr 07, 2014 | Brother XL-3510 Mechanical Sewing Machine
I have a bernina Activa 180 sewing machine. I tried to follow your earlier instructions for removing the race and shuttle; i.e., using a lever at the upper left. I do not see such a lever. Would you...
Actually, on your machine its a large plated flat spring to the left of the bobbin door, not upper left (sorry!) you just press it to the left and the 'U'-shaped metal retainer and black plastic ring that holds the shuttle in should pop forwards and/or drop down onto the bobbin door on a hinge. The hook race in which it sits does not come out - that's screwed-in. Hope that helps.
Oct 24, 2011 | Bernina Activa 130
Should the machine have some oil? Where? It is a Bernina Activa 130
The Activa range is fitted with a light-weight part-plastic hook/shuttle that Bernina claims does not require oiling. However, this does not mean it shouldn't be regularly cleaned and I'd recommend that it is also lightly oiled at the same time. Remove the bobbin case, press the metal lever to the top left of the bobbin door and the black plastic hook/shuttle retainer should pop open so that the hook/shuttle can be removed, or it will just drop out anyway. Use a cotton bud to firmly clean around the inside edge of the hook race (the round piece that the hook/shuttle sits in. Give the whole thing a good clean to make sure any surface grime/fluff is removed. Put a small drop of oil on the running surface of the hook race - the recessed groove around the inside edge, before replacing the hook/shuttle and holding in place by pressing the hook/shuttle retainer back until the securing lever clicks back into place. Rotate the handwheel once to distribute the oil and off you go. Dont overoil but do this regularly and your machine will run much quieter and produce a consistent stitch formation.
Jul 07, 2011 | Bernina Activa 130
I took out the bobbin case and then the shuttle race. Now I can't remember which one I should put back in first.
Clean the shuttle area, the hook and the cover with a toothbrush, removing all lint and debris. Place one small drop of sewing machine oil on the rim of the hook. Place the hook back in the raceway and replace the cover. Snap the two retaining levers back to hold the cover in place.
Jun 02, 2011 | White Sewing Sewing Machines
Brother XL-2022 Bobbin Problem
Removable parts are the race and bobbin case.
Raise the needle to it's at the highest position and set the race hook into the shuttle so the hook is at the lower left.
Re-place the hook race cover and move the levers or pegs to hold the cover in place.
Apr 18, 2010 | Sewing Machines
Bobbin don't turn
In the shuttle area there is a silver round piece- called the shuttle race cover. It has a black ear on the right and a black ear on the left. Push the right ear to the right, and the left ear to the left and the silver ring should come out. Behind the silver ring is the bobbin case stuck in the hook. Remove that, jiggle it, move it, just work the bobbin case out of the hook. Now put the hook back in the machine. In the machine there is a driver that looks like a half moon. Your hook looks like a half moon- make a full circle out of both of them. Re-install the race cover, pushing the left ear to the right and the right ear to the left to secure the race cover, and your problem should be solved.
Jul 01, 2009 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
46 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
