Question about Dryers
How to reverse sunbeam Fan motor model M616ADR Best regards Mike
Hi, I have a sunbeam Fan model M616ADR the board burnt and i couldn't find a new board, so i tried to bypass the board and connect direct to the motor on the red wire(high speed)and either the black or grey but the fan turns counter clockwise sucking air from front to back, so the question is how to make the motor turns to other direction knowing it's an AC motor not a DC motor, which color of two wires to supply 240 volts to make it turns clockwise not counter clockwise. Thank you in advance Best regards Mike
3 Suggested Answers
farfield
  • 462 Answers
SOURCE: RV AC, how to wire fan (blower) motor to capacitor.
You almost have it Look closer at the run capacitor. It has Herm, this is for the compressor, Com or C and F or Fan.
1 of your power wires is the fan speed so connect them accordingly usually black is hi, blue med, & red is low. You are "feeding" voltage to the selector switch on 1 side and coming out to the fan motor speeds.
Next you have a "Common" wire on your fan motor (this means its Common to all the other connections inside the fan motor to me. It is usually white. Connect this to the other line of power usually the Com on the capacitor unless it connects to a strip on the selector switch. But 1 of these 2 places will be the other side of your Power when plugged in. Lastly the brown it is usually the fan capicator only wire and it will connect to the fan "F" terminal on the capicator this terminal will not have any other wires connected to it.
This should make you a happy camper. Please rate me accordingly and good luck.
Posted on Mar 08, 2009
  • 119 Answers
SOURCE: goodman heatpump model cpke30-18 installed new in
Does your new motor have two sets of short wires with connectors in the middle of them? If so then it is reversible and the instructions for doing so are printed on the motor data plate on the side of the motor.If it does not have these wires then reverse the polarity of the two power leads as they come off the top of the contactor, that should fix your problem.
Posted on Jun 24, 2011
Mixer on my Sunbeam Model MX5900 compact mixmaster has burned out because beaters kept jambing in each other. Can I purchase just the mixer and beaters? Stand and bowl are OK
If the motors had burnt out then the winding can be redone if you can get this job to a winding shop.
Other wise the motor and assmebly can be ordered from a Sunbeam service outlet. try and see if you re able to source a motor assembly from a damaged/scrapped set with a mechanical defect.
Sep 20, 2011 | Sunbeam Food Mixers
I have a sunbeam mixmaster from an Aunt that is at least 30 years old and it recently just stopped working. I assume that the motor is blown. Is it possible or worth it to fix it ?
If the motor is blown it will most likely cost more to repair or replace the motor than buying a new mixer. However, It could be a break in the electrical cord or at the plug. Is there a 'burnt' smell in the mixer? If not, have the electrical cord checked by someone in the know before purchasing a new mixer.
Please don't hesitate to ask me should you need any more info.
Best wishes,
Graeme.
Nov 30, 2010 | Sunbeam Food Mixers
I have the Sunbeam portable mixer 2486. I was making Parker house rolls with the dough hooks. After blending the dough, the mixer just stopped. The motor will no longer be turned on or off. I want to...
Hi Janis.
You have likely burnt the motor. That is the most common fault when the mixer is used for a prolonged time on a compact dough.
The best thing to do is ringing Sunbeam at the number listed on the owners manual, and checking what conditions for repair are offered.
If you have misplaced the manual, then track the number using Sunbeam website: Sunbeam.
Regards.
Mar 02, 2010 | Sunbeam 2485 MixMaster Series Hand Mixer
Keeprite furnace will come on heat up but the fan or blower doesn't blow but creat noise. please tell me how can I fix it. Regards Andre
Blower motor is either burnt or Ihave also seen the fan relay on the board burnt..test for 120v power out of the board at the blower leads if so replace motor, of no replace board
Feb 06, 2010 | Omega Keeprite Furnace Flue Exhaust Venter...
I have a ceiling fan that the blades are in reverse mode. Where should the switch that changes the blades direction be located?
Helo there:
providing that this has that capability the switch will be on the side of the housing of the fan or on the very top. ok?
best regards mike
Aug 15, 2009 | Hampton Bay Dryers
Our GE Arctica PSS27NHN has gone out. We took a look inside and found the motherboard has a burnt spot, so that is most likely our problem. Can anyone tell me if this model is on the recall list. I have...
No recall list that I know of .G E now has 2 boards available . The pt# you need is WR55X10656 . Less problems than a board for each model .
Jul 19, 2009 | Refrigerators
Condenser fan running backwards on heat pump
I am having the same problem, sometimes it runs in the wrong direction, blowing the air down. Sometimes something gets tripped and I need to turn the thermostat to off and wait a bit then restart it. If I am lucky it will run int the correct direction and also will warm the house. Sometimes it send nothing but cold air to the house's forced air.
Jun 13, 2009 | Goodman CKL24AR24 Air Conditioner
Model 1456 n19811 how to reverse conveyor
If it's 3 phase, just reverse 2 of the 3 motor feed wires. It doesn't matter which 2. If it's single phase, the wiring directions should be inside the motor where the wires go in.
Dec 16, 2008 | Lincoln Conveyor Oven - 1133-000-A
Board dead
Depending what type of phone service you currently have. You can call Asus tech directly. M-F, 9:00AM to 5:00PM. EST
At: 1-812-282-2787. It will take about 2 minutes to get connected with a tech (The people who do repairs on MB's). Give them the location of the capacitor & motherboard model number.
Good Luck!
Mike
Jun 12, 2008 | ASUS K8V-MX Motherboard
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
