Question about Garden
My ariens 8524 doesn't blow snow very good,whats wrong? sheir pins are good and i put a new auger belt on it
  • Garden Master
  • 2,290 Answers
Does your engine rev up the way it should. You can't blow snow very well if you engine is at half speed.
Posted on Dec 24, 2016
I need sheir pins what kind?
depending on your machine. they sell 1/4" diameter pins or bolts to fit threw the augers holes
Dec 29, 2015 | Garden
How do you put it in neutral
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
May 13, 2014 | Rotary Snow Blower Parts Replaces Ariens...
Auger does not turn
If the high speed impeller is turning, but the auger is not, there are 2 failure modes:
1. The sheer pin attaching the auger to the shaft has sheared. There is one shear pin on each side. This is an easy fix. Buy a new shear pin. Do NOT use a regular bolt.
2. The gear box between the 2 augers is broken.. This is an expensive fix and requires modderate skill for a DIY fix.
If the high speed impeller is not turning, it is likely the belt is broken between the engine and the blower. This is a relatively easy fix.
Feb 05, 2014 | Ariens Garden
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Ariens st350 snow blower wont blow snow, augers wont spin
there is a bolt that goes thru auger and spinning shaft (look for a hole where it once was) holds the augers to the spinning shafts, it is called a shear pin, it is a safety feature, and made of softer metal, so if you pick up something too hard with the auger, it wont lock up the engine, or break engine crank shaft.find an ariens repair shop to purchase the shear pin so you get the right softness of metal.
Mar 05, 2013 | Garden
I own a 2 stage snow thrower by M T D, recently, I can only move it 2 feet before I have to back it off because the snow gets clogged up. There is not an unreasonable amount of snow in there either. HELP
Hi, I will try ro help you out. It sounds as if you probably have broken shear pins on the auger, and that is why as soon as snow gets in there the auger stops. If you look on the auger shaft you will see probably 2 bolts. They are made to break if something like big ice or debris gets in there so that parts are not broken or bending parts of the auger. All you have to do is replace the shear pins. That is what I think is wrong. That is all I can think of that it could be. All the best and good luck. Happy to answer any other questions.
Feb 03, 2011 | Ariens 34 In. Zoom Series Riding Mower
I have a arien snow blower (924 series) that does not blow snow out the impeller. the auger just pushes it. bothe the impeller and the auger turn. the shear pins for the auger are in. the rear key...
Run the impeller without any snow coming into it--hold your hand over the exhaust of the impeller to check for considerable wind force. If almost non existent, make sure the impeller is being driven at full speed. Is there a shear pin related to the impeller? The only other problem would be if the impeller was running the wrong direction, but I don't see how that would be possible. Hold the impeller with your hand while trying to turn the pulley--there should be no slipping between the two. Hope this helps!
Jan 03, 2011 | Garden
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
Auger turning slow. Auger turns initially but auger stops turning when it hits the snow. Shear pins look ok, belt looks ok. Shear pins look intact. Could they be broken inside where I can't see.
sure sounds like a shear pin, usually one end will be missing if it is broke. They are simple to replace but get one that is rated for your machine to avoid damage. Can you turn it freely without the engine running?? if so, it's the shear pin
Dec 14, 2009 | Ariens Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
