Ikbc3845 can I hook up a FM antenna - Audio Players & Recorders
3 Suggested Answers
  • 125 Answers
SOURCE: how to get am/fm stations to play. I have a hook
you can buy one online or you can make one out of audio, lamp, or antenna wire. cut about 10 ft of wire and split the wire about 1/4 to 1/3 of the way. that is to pull the two ends at one end of the wire in opposite directions. the wire looks like a T. the bottom of the T hooks to the receiver, the other end spreads out along the wall. the 2 ends at the rec. hook to fm and gnd or am and gnd. i hope i have made this clear.
reply if you need more help.
please rate bama46 and have a great day, thanks
Posted on Aug 23, 2009
  • 6771 Answers
SOURCE: i have a old pioneer stereo double cassette deck reciever model # RX-Z15, i dont understand the bal/unbal fm antenna hook ups cant get reception , need to know where to hook up the antenna or what kin
Buy a 300ohm FM Y antenna wire screw the spade ends into the balance hookup and fasten the Y section on your wall, "higher the better" this will improve reception. The antenna can be purchased at Radio Shack or Tv repair shop.
Posted on Apr 20, 2012
There is no electrial retailer in bendigo that has fm aerial to suit this is why i am asking you
Make your own.
  • How to Make an FM Antenna: 8 Steps (with Pictures) www.wikihow.com/Make-an-FM-Antenna
    • 832K VIEWS
    2016-01-11 ยท How to Make an FM Antenna. Improving the reception of commercial FM radio (88Mhz - 108Mhz) can be done by you at home, simply by replacing the antenna ...
  • Simple FM Radio Aerial - Robert Sewell www.robertsewell.ca/yahoo/fmaerial.html Simple FM Radio Aerial A simple FM radio aerial can be made using about 5 feet of old 300 ohm TV downlead, an alligator clip and some hook-up wire.
  • Or try Jim
  • Antenna Installation Bendigo
    May 23, 2016 | Audio Players & Recorders
    Can't pick up am channels
    Do you have the AM antenna hooked up? FM and AM need a separate antenna for each. An AM antenna is usually a "loop" antenna, which is a wire coiled around a frame.
    Dec 23, 2012 | Audio Players & Recorders
    I have a old pioneer stereo double cassette deck reciever model # RX-Z15, i dont understand the bal/unbal fm antenna hook ups cant get reception , need to know where to hook up the antenna or what kin
    Apr 20, 2012 | Pioneer Audio Players & Recorders
    Sanyo dcx686 am/fm amp receiver no fm reception
    you should be able to hook up any am/fm antenna, like the new ones that come in a square and hook it up to the two left-most spots for a radio antenna, thats how i have mine. as for the manual, you can order them off of a site(if you can find a reputable one) if you search SanyoDCX686 on google. hope thats somewhat helpful =]
    Dec 14, 2011 | GPS
    How do i hook up an antenna to the pioneer sx-950
    There are two antenna sources on the Pioneer SX-950.
    Both of these outputs are located on the rear panel of the receiver. The AM is a permanent mount. The FM is standard RF/Coax which will run to your antenna.
    Antenna Inputs: FM 75 ohm, FM 300 ohm
    Am Ferrite Bar Antenna
    Hope this helps,
    TechGuy21
    A
    s
    Jul 04, 2011 | Audio Players & Recorders
    How to get am/fm stations to play. I have a hook
    Aug 22, 2009 | Yamaha RX-V793
    Sherwood receiver rx-4105 fm doesnt pu any frequency (just static) , am does
    You need to hook an antena to the back of the unit (A peice of speaker will do!) you should see a screw in back of uniGood luck and Thank you for using FixYa.
    Dec 17, 2008 | Audio Players & Recorders
    Cb feedback though external am/fm speakers
    Hi Big OX,
    Terrible problem.  I know what your going though.  Route your AM/FM Antenna wire, and Speaker wires separate from the  CD Antenna cable and power supply wires. If you can,  twist the speaker wires.  If the Speaker wires are run along side the CB Antenna wire for a short distance, you will pickup feedback. If you much have the Antenna wire get near the speaker wires, have the antenna wire cross the speaker wire at a 90 degree angle. Try not to run the antenna wire in paralell with the speaker wires.   Good luck
    Oct 27, 2007 | Car Audio & Video
    Cannot Get Antenna To Pick-Up Signal
    If your roadyxt came in a red box then you need to hook up the XM SureConnect to your vehicles antenna. The instructions that come with it are simple and straight forward. Your FM transmitter will not work unless you hook up the sureconnect
    Aug 25, 2006 | Delphi Roady XT XM Radio Receiver
    Fm reception going in and out also strange noises
    Hooking up the AM antenna loop should not have fried anything, as I know lots of peeps who have done that. The FM RF amp. sounds like it may be at fault. The only way to tell if its bad is by hooking up an RF generator and I would be surprosed if you had one of those laying around. Disconnect the unit and take it to a repair shop.. If its an older model Time to get a new one. Good Luck
    Jul 23, 2006 | Philips FWC155 CD Shelf System
     Grubhead
    Grubhead
