Question about Retail Supplies
How do l set my T290 to print receipts? - Retail Supplies
I have a Cash reigister PCR T290, the print out is already blurred, what will I do?
Hi. Try cleaning the print head and changing the paper for a different brand. If it still prints blurry, the print head is probably faulty and you need a new printer
Aug 01, 2017 | Retail Supplies
Pcr t290 PAPER WON'T ADVANCE
Make sure the paper is the correct width. Does it print or advance if you try to print a daily report?
Sep 18, 2013 | Casio Parts Cash Register PC Desktop
Won't print ie8 based receipts
It sounds like a configuration error please check all settings and confirm that they are all correct if not correct as necessary. It may also be a conflict between the 2 printers it maybe trying to print to both and cannot due to seeing 2 printers. If you have checked all your settings and they are correct try removing 1 printer and then if it prints on either singularly then it is a error that needs correcting on the settings for your printers to be able to be used together correct this problem and then you should have no problems. I hope this helps.
Sep 12, 2012 | Computers & Internet
We just got a new xe-a102, we do not need to print receipts...how do you turn off that function?
To disable receipt printing:
  • Press the Rcpt/PO key in the OP X/Z position. This key toggles the receipt printing status ON andOFF.
  • To check the receipt printing status, turn the mode switch to the OP X/Z position or press the CL key in the REG mode.
  • When the function is in the OFF mode, the receipt off indicator “_” illuminates.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function in the OFF
mode, press the RCPT/PO key. This will produce a receipt. If more than 50 items were entered, the receipt will be
issued in a summary receipt format. Your register can also print a copy receipt when the receipt ON/OFF
function is in the “ON” status.
Oct 27, 2009 | Sharp XE-A404 PC Desktop
How do i get it to stop printing customer receipts
The following is the process to stop customer receipt printing. It will also describe how to print an individual receipt on demand. Best of luck and thank you for using Fixya! Kindly return to rate this solution.
Greg
Receipt ON/OFF function
You can disable receipt printing in the REG mode to save paper using the receipt ON/OFF function. To disable
receipt printing, press the Rkey in the OP X/Z position. This key toggles the receipt printing status ON and
OFF.
To check the receipt printing status, turn the mode switch to the OP X/Z position or press the lkey in the REG
mode. When the function is in the OFF mode, the receipt off indicator “_” illuminates.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
"To issue a receipt when receipt ON/OFF function is set to OFF:
mode, press the Rkey. This will produce a receipt. If more than 50 items were entered, the receipt will be
function is in the “ON” status."
Sep 24, 2009 | Sharp XE-A404 PC Desktop
Automatic paper adjustment
Goto File, Page Set Up, Margins.
Be sure "Marigns" is in the "Inches" setting.
Enter 3.0 inch in two boxes; Topp, & Bottom.
Good Luck,
Aug 04, 2009 | Epson LQ 580 Matrix Printer
Change on/off receipt function to off
The following is the method to turn the receipt printing on/off:
OFF.
All the best!
Greg
Aug 01, 2009 | Sharp XE-A404 PC Desktop
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
Epson TM-U220D Receipt Printing Problem
mau download driver epson tm-u220d ga ada...
klo mau cari dimana yah
Oct 21, 2008 | Epson TM-U220 Matrix Printer
Retail Supplies Logo
48 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
