Question about Craftsman Garden
Craftsman zero turn 26 hp kohler engine new pto electric clutch does not work
    Visited the website for 20 consecutive days.
  • Craftsman Expert
  • 242 Answers
Sad to say it may have never been a bad pto clutch but probably safety switch problem. The running tractor wants you in the seat, brake off, levers over your lap and not backing up for the PTO to stay engaged . There is two push button switches on each lever that lay over your lap ,one on the parking brake,one under the seat. All of these switch wires meet at the PTO switch and all have to agree they are in the position they need to be in to allow electricity to come down the wire to the PTO Clutch.
Posted on Dec 22, 2016
First determine if you are getting 12 volts to the PTO switch and then 12 volts to the clutch. You can also Ohm out the clutch before replacing. The Ohm reading on the clutch should be between 2 - 4 ohms.
Jan 10, 2017 | Craftsman Garden
Was mowing fine then motor began surging and now blades will not engage or disengage
Because the mower began surging and now the blades do not work, I am thinking something electrical. The PTO and electric clutch would be where I would start. The clutch can be checked and should read 2 -4 Ohms.
May 13, 2016 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Electric clutch wont engage when when switched on even though I can hear a clicking sound at the clutch.
PTO Clutch will not stay engaged.
There is a very fine one page discussion on evaluating electric clutches at this site:
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
It does not give the air gap. It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 11, 2015 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Kohler CH640-3075 (one year old and in a Grasshopper 720K) will not turn over. Battery charged.
check fuses first. then check starter solenoid for proper power and then this will lead you to either a safety switch issue or a power issue...
turn key on, pull pto switch... does pto engage, then your problem is at or after the key switch
Oct 08, 2013 | Kohler Engines New 20 HP Kohler Engine...
Engine starts without sitting on seat
check the safety switches bypass them one at a time to find the bad one the seat the clutch/brake pedal the pto lever
Apr 20, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Just replaced pto clutch brand new ,wont engage.nothing, zip not a movement.
Check that you are getting voltage to the wires that connect to the clutch when you switch on the pto. If not check that you are getting voltage to the pto switch. If you are the pto switch is faulty. Regards Phil
Apr 15, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I would say replaced to ensure correct opperation.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Craftsman 54 in lawn tractor W/ 26 hp Kohler engine
Could be, but test each item with your tester. Test key switch (12V in and 12 V out when turned to start., operator present switch 12V in 12V out (seat) Clutch switch, etc. till finally you test for 12V on the small terminal on the starter solonoid. Happy testing!
Jul 19, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I had the same problem so I looked under the mower and the belt that goes from the engine to the back of the mower was off so I pushed the clutch as far forward as I could and the belt went on it and it worked
May 29, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Garden Logo
43 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
