Question about Kitchen Ranges
Reset button doesn't work on classic bay stove. We replaced snap disc#2, but still doesn't work. Any suggestions?
3 Suggested Answers
SOURCE: why doesn-t it work the send button of yahoo.mail?
i have the same problem
Posted on Jun 26, 2009
SOURCE: Kenmore Classic Wall Oven Model #
I think that the ONLY problem is to set properly the TIMER; The TIMER is set OFF and the OVEN does not work; try to push and/or release the timer buttons and it will work. I have the same problem and it is very unfortunate that I have no manuals.....
Posted on Feb 07, 2011
The display and buttons are dead, no display or oven lights but electric starter still works on stove top
find the breaker for the stove and turn it off for 2 minutes then back on, if that does not work look on back of stove in area of controles for a small reset button, some time they are hidden just inside a small hole
Jan 09, 2014 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
We have a Zannusi zdc37100W tuble dryer, it wont stay on, we have cleaned filters emptied tanks etc. I suspect the sensor is broken or blocked. Error code 5 red 1 green is being displayed
Although I admit not having worked on this brand; the problem seems to be with the "snap disc" thermostat!
It is cylander shaped with 2 wings that have screw holes. Its silver side faces toward the heating coil when mounted with 2 machine screws. 2 wires are attached on the "black side" facing you.
These disc are for your protection.
They prevent the "heating coil" from raising the internal temperature of the dryer above 248 degrees F.
They re activate the coil when it cools to 80 degrees F.
It should be located above the top of the "heating coil housing".
1)Disconnect the power supply
2)Locate the Snap Disc
3)Remove the 2 "quick connect" wires from the flat electrical contacts on the Snap Disc.
4) Remove the 2 mounting screws (careful not to drop them inside the dryer)
5)Remove the old Snap Disc & Replace it wilt a new one.
6)Mount new Snap Disc with the 2 mount screws.
7)Connect the two wires with the quick connect fittings onto the flat electrical contacts.
8)Put all access covers, lids,clips or anything else you removed to gain access to the Snap disc back where they belong.
"Make sure that no bare electrical contacts com into contact with anything that you put back"
"Don't (pinch) a wire during this process!)
Note: You can order your part from a variety of places.
Have ready before calling: The Make, The Model # The Serial # (just in case they ask for it) of your dryer.
Have The old Snap Disc in your hand so you can give them the part #.
Most "Home Use" clothes Dryers that work on 220 volts use a
Snap Disc "Labeled": L248-80 F
Good Luck! Ihope this helps!
Oct 26, 2013 | Zanussi ZDC37100W Electric Dryer
Stove top and oven doesn't work.
If it is an electric stove it may have tripped one side of the 230 line. Check the house cuircuit breaker panel and find the stove circuit breaker. It will be tied together by a bar or clip. Shut off both breakers completly and reset them back completely. If it is a power problem this should reset the stove.
Dec 01, 2012 | Kitchen Ranges
With a combined TY/DVD player I can't clean the interior, as suggested. Nor did turning on and off work either. Other suggestions?
Try using an aerosol computer cleaner or compressed air to blow out the bay while it is in the open position. If this doesn't work then it could be that the laser eye is bad or stuck. DIY isn't always the way to go so you might want to send this one into a repair shop. Your local computer repair store should be properly equipped to handle the task.
Aug 31, 2012 | Toshiba Televison & Video
How yo fix camera an stand bay nokia 6700
Hi.If you can remove the cover at least clean the PCB mainly the camera and it's nearby components.Otherwise contact mobile repairing shop.Generally if the camera of a Nokia Handset doesn't works automatically you could not play video.Thanks for visiting fixya
Mar 26, 2012 | Nokia 6700 Classic Cell Phone
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
      taskkill /F /IM dwm.exe
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
The oven won't turn on. We are unable to set the clock either. The display flickers but doesn't display.
There are lots of different timers on fisher and paykal The last one I reset was a few weeks ago it involves pressing 2 buttons at the same time I think it was the oven on and oven off buttons but I am not sure You will know when you have pressed the right 2 buttons the display will stop flickering set the clock time using the up down arrow buttons The auto light should not be on if it is press the manual button Regards Geoff Stove Recyclers
May 29, 2011 | Fisher Ovens
Kenmore Classic Wall Oven Model # C97047191-2 Serial # NF91008197 nothing on it works (was fine last night) checked the 3 fuses under the stove and the breaker is good on the electrical panel. Is there...
Oct 05, 2010 | Ovens
3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Jul 23, 2008 | Hunter 23852 Classic Original Ceiling Fan
Kitchen aid stove problem
Peter, sure you cut power to the stove before you do anything. This is 220 volts and it can kill you. 220 Volts is based on two different lines of power coming to the stove, each of which is 110 volts...but opposite each other in phase. This may mean that some power to the stove is on and some is not. Let's go on.
I suspect a few things: First, the coil control for the burner is probably finished. What I also suspect is that it opened one of the two breakers (they are usually tied together in the panel and are either 40/50/60 amp units) causing some lights but no action.
What to do: Reset the breakers as a pair by turning them off and on. If one snaps off, you have a problem at the stove. If not,...which I're in business.
Let's look at replacing the control. Shut the breakers. Now, take the burned control and remove it. Note the wiring positions if they are not on a plug. If they are terminals, tape the ends. Now, reset those breakers. If the other burners work, replace the control. Take the old one to the parts store. If it doesn't work, look around the burned area for broken wires. Repair and tape them up. Try again. Oh, and don't let anyone touch the stove while you're working with those breakers.
Dec 03, 2007 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
