Question about Baby Gear
Reade this simple instructions and this crib will not lock and stay.
28 year old Jenny Lind Crib
Did you ever find the instruction for your Crib? We have the same issue with our Crib.
Apr 15, 2010 | Evenflo Jenny Lind Crib
Need Replacement Part # 4 X H Crib Lock for Delta Lov Crib Model 4720
OUR DELTA 5 IN 1 IS MISSING THE RAIL GUIDE 4 X H CRIV LOCK AND #10 DOWELS AND NO INSTRUCTIONAL GUIDE HELP??
MZ Q
Oct 16, 2009 | Delta Luv Delta - Baby Products 5-in-1...
INSTALLATION OF EVENFLO SIMPLE STEP
Go to this website and you should be able to find the instructions
http://safety.evenflo.com/cs/sc/cssc_RD.phtml
please take a moment to rate this solution thanks
robert
Sep 03, 2009 | Baby Trilogy Spindled Corner Crib
I have a new pack an go playpin without instructions. HJow do you lock the sides to stay up?
The bottom cannot be flat for the rails to lock (or unlock), raise the bottom half way and it should work. Really a pretty good safety feature!
Jun 10, 2009 | Baby Gear
Looking for assembly instructions for Babi Italia Gina Crib...
EMAIL THIS PERSON. THEY SENT ME THE INSTRUCTIONS ON THE BABI ITALIA GINA CRIB. IT WILL COME IN PDF FORM.
receptionist@lajobi.com
Apr 04, 2009 | Baby Gear
Need instruction manual for Evenflo crib model # 9021
I have the paperwork/instructions that came with our crib...model 9021. If you still need it email me at beaglebabe05@gmail.com and I'll scan it for you.
Dec 13, 2008 | Evenflo Jenny Lind Crib
I need assembly instructions for Jenny Lind crib # 02616
assembly instructions for jenny lind crib 012616
Nov 19, 2008 | Evenflo Jenny Lind Crib
Instructions for Avalon ''On the move series'' playpen
I have had this problem with one of my daughter’s playpens. What I did was take the mattress out then pull the bottom part up. After that I pushed the buttons underneath the top rails and pulled up on those as well. For some odd reason this playpen WILL NOT collapse until you pull the bottom up. Hope this helps.
Nov 15, 2008 | Baby Gear
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Baby Gear Logo
43 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
