Question about Ovens
It will lock by its self - Ovens
  • kakima Dec 22, 2016
    Hi Paul Katzke, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model is "it"?
Spectra oven. It was going through a self cleaning cycle and was shut off partially through that cycle. Now the door is locked and won't open up. Help!
Door lock has failed to open after cool off start oven into self clean again leave on for a 1/2 min. then cancel self clean motor for self clean should return to normal or lock switch need replaced need a model # on were lock motor is located
Jan 30, 2017 | Ovens
Self cleaning
Set back on self clean, then after about a minute, switch off. The lock should disengage.
Apr 25, 2013 | Bosch HBN 442 / HBN446 Electric Single...
The lock on our self cleaning oven will not lock when we press the start button for self cleaning
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 12, 2011 | Whirlpool Ovens
I'm trying to self clean the oven. I am following steps in the manual- however, when I press start to self clean, the door lock light flashes, then beeps and the oven turns off. The manual says the door...
heatman101
Nov 23, 2010 | GE JTP15 Electric Single Oven
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Apr 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire self clean electric stove 'f9' message comes on when self cleaning
I had the same problem. All I had to do was clean around the door lock. A small bit of burnt food or something had gotten into the hole around the lock and prevented it from moving all the way into position. Took a tooth pick and 30 seconds of probing to clean it out. Works fine now.
Oct 13, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Wont lock in self clean
Whirlpool Gold range: start the self cleaning but after message: cln door comes message, E1-F5- . door does not lock and cleaning can not start.
Oct 10, 2008 | Thermador C302U Electric Double Oven
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
21 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
