Question about Coffee Makers & Espresso Machines
Our royal cappuccino will not power up. - Coffee Makers & Espresso Machines
I need an owners manual for the Saeco Royal Cappuccino machine? SUP016R manufactured in 6/2006
Scroll down this page:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
You can download the manual for your Saeco Royal in a PDF format.
Hope that helped! Thanks for using FixYa.
Jun 10, 2010 | Saeco Royal Cappuccino Espresso Machine
Saeco cappuccino royal wont steam or ventilate
Hi
You have a stuck solenoid or a plugged stream tip.
May 23, 2010 | Saeco Royal Cappuccino Espresso Machine
Cleaning of saeco royal cappucino machine
The user manual shows you how to clean your machine. If you don't have it you can download it from the Saeco site:
Apr 09, 2010 | Saeco Royal Cappuccino Espresso Machine
I have anew royal professional the milk throther,
Aren't you supposed to foam the milk in a seperate container with the steam wand?
Jul 02, 2009 | Saeco Royal Cappuccino Espresso Machine
My Saeco Royal Cappuccino Coffee machine says "refill water tank' when it is already full. I only use filtered water and have descaled the machine. How can I fix this?
This sounds like the water sensor needs replaced //Also make sure the inside float is not stuck in the down posistion!
I hope this helps!
Dec 13, 2008 | Saeco Royal Cappuccino Espresso Machine
Saeco royal cappuccino coffee machine beans container empty fault
Hi
More than likely your grind is to fine. Push the lever back 1 # larger(Higher #). If you want stronger coffee, push the doser lever on the door to the back then pull forward 1 click.
Oct 30, 2008 | Saeco Royal Cappuccino Espresso Machine
Selftest sign
Try to make a cup of water(tea), press the button for water.
On the old Royal Cappuccino that are the button on the right down corner and the new machine had it on the upper right corner.
Hope this will help you.
/Mirran
Aug 16, 2008 | Saeco Royal Cappuccino Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
