Question about Water Water Heaters
Water purification system under counter installation and service video
Ariston water heater service center
Copy following link for Bosch Ariston water heater resources:
http://waterheatertimer.org/Ariston-water-heater-resources.html
You can fix this water heater yourself, or buy another under-counter water heater if tank is leaking because anode depleted.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 29, 2013 | Water Heaters
Insinkerator instant hot water faucet
Insinkerator stainless tank does not have anode rod to protect from rusting. So these water heaters rust out at welds. And must be replaced. And this is frequent problem.
Copy following link for installing under-counter water heater and see manuals for various models available. Non-insinkerator water heaters have anode rod to protect from rusting:
Gene
Jul 23, 2013 | Water Heaters
Tank
Insinkerator has stainless steel tank but does not have anode rod to protect against depleted tank wall.
Leaking tank means broken weld, and you must replace tank.
Copy following link for tips installing under counter heater
Add comment as needed and fixya will send me email to reply with more detail as needed
Jul 15, 2013 | Emerson InSinkErator W-152 Point-Of-Use...
Atwood water heater electronic ignition
Copy following link for possible troubleshoot resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Might want to call service technician instead of messing with gas appliance.
Or sent to service center.
Install 20 gallon under counter electric water heater and connect to 120Volt... 1500 watt element will heat water pretty quickly. To have more hot available, turn up water heater thermostat, then that will give 2 showers because more cold will be added to very hot water, thereby stretching amount of available hot..
Add a comment as needed
Jun 02, 2013 | Water Heaters
What is per unit price of this item
Copy following link to identify various brands under-counter water heaters and read product manuals and see installation tips:
Local home centers sell under-counter water heaters, or order online at Amazon etc
Add a comment and say what you are doing
May 27, 2013 | Rheem RUUD EGSP6 208V Water Heater,6g...
Need to add electric heating element and thermastate to g6a-6e gas water heater
I don't know how you can drill into aluminum tank and install element.
That seems a good way to ruin the heater.
Why not just buy small 'under counter' 1500 watt electric water heater at local box store and install in-line before the water reaches atwood gas heater.
Otherwise I do not have a solution.
Don't blow yourself up by messing with gas appliance.
Mar 16, 2013 | Water Heaters
How can i install my hot water heater model 71-408 b
71-408 is probably electric water heater.
Unknown brand, unknown type.
Water heater comes with product manual with step-by-step instructions.
Example instructions:
http://waterheatertimer.org/pdf/How-to-install-electric-water-heater.pdf
If this is under-counter model:
Oct 25, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do you winterize Model GE20P06SAG? There is no drain at the very bottom...?
Thank you for including model number for EZ identification of water heater
To drain tank without drain valve: Remove TP valve at top of tank and siphon out the water. Then reinstall with correct pipe configuration shown in product manual.
Product manual shows drain valve is not supplied with this unit.
http://waterheatertimer.org/pdf/GE20P06SAG-under-counter.pdf
Product manual shows the Installer should add both shut off valve and drain valve on cold water inlet line.
http://waterheatertimer.org/images/GE20P06SAG-under-counter-60.jpg
More resources:
Sep 30, 2012 | RELIANCE 19.9 Gallon Electric Compact...
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
