Question about Cooktops
Minn kota rt 74 riptide how to wire plug
Has 2 red 2 black
Maytag cook top Model # CSE 9000 ADB. A red, black, blue, yellow, white, and bare copper wire come out of the unit. How do I hook it up???
each colored wire is for a seperate burner, the white wire connects to the white neutral wire the bare wire connects to the ground the red and yellow wires connect to the red wire (L1) and the black and blue wires connect to the black wire (L2). i have the same model and i connected mine this way and it's working fine. mine is also connected in a box that has a seperate fuze for each burner so you can follow the red (L1) wires to the 2 fuzes and connect your red and yellow wires to these fuzes and the follow the black (L2) wire to it's 2 fuzes and connect your black and blue wires to these fuzes. i don't know if this box is necessary or ir you can just connect directly to the wiresin a regular box and rely on the breaker but it was already there from the old cooktop i replaced so i used it. hope this helps you
Jan 07, 2011 | Maytag 30 in. CSE9000 Electric Cooktop
Do i connect the red and black wires together
No you do not. You have a 220 system. What you do to hook it up is. In the box in the wall you should have 3 wires. 2 black and one white. Then on the cooktop you have the 3 wires 1 black, 1 red, and 1 white. You take the black from the cooktop to the black in the wall box. Take the red to the other black in the wall box. then take the whites and put them together. Now if you have a green or bare wire that is the ground. Just hook that to the wall box.
If you have any questions please ask.
May 09, 2010 | Jenn-Air JED8230 Electric Cooktop
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
On-site breaker panel routing
white and ground are grounds there should be a ground rial in the fuse box, stove is 220 black and red go to 2 seperate breakers, 25 amps, and 15 amp is for 110 regular outlet
Oct 08, 2009 | GE Cooktops
Wiring Wrong
REDS ARE THE 2 HOT 11O VOLTS EACH AND BLACK IS THE COMMON FROM THE CIRCUIT BOX .THE RED ON THE STOVE SHOULD BE 1 HOT AND THE GRAY MAY BE THE COMMON BUT YOU ARE MISSING A HOT LOOK FOR YOUR WIRING DIAGRAM ON THE STOVE AND IT WILL SHOW YOU THE COLOR CODES FOR WIRING IF YOU CANT FIND IT SEND ME THE MODEL NUMBER AND I WILL SEE IF I CAN GET IT FOR YA.......BILL
Jan 11, 2009 | Cooktops
Cooktop wiring
usually black(120v) white (n) and red(120v) bare wire to ground, but if htat what yo got and your sure of incoming voltage, blabk to black , red to red, and white to white is normal..co loang as you 2 power legs are hooked to either power line, the bare goes to the nuetral/ground. thikn i mighta confused myself here, but theres no other way to wire it
Nov 07, 2008 | Cooktops
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Wiring installation
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
Apr 14, 2007 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
85 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
