Oscillating heater INTERTEK model LH-894 making noise and the low heat noT working
Where can I get a manual and is there a 800 number
SOURCE: 2000 watt baseboard heater is making loud clicking noise
Most base board heaters installation instructions say to attach to the wall with screws which are slack ( not fully tightened) in order to allow the heater case to expand and contract otherwise you get a clicking noise
Posted on Oct 31, 2008
  • 4 Answers
SOURCE: Grindin noise on My 97 Dodge Caravan when heat is turned on .
yes,could be something in there rubbing against fan cage.
Posted on Nov 23, 2008
dr_greg
  • 192 Answers
SOURCE: honda heater makes loud noise
ok well its possible there may be something stuck in the blower motor under the passenger side dash. ..or the blower motor itself could be on its way out, sometimes leaves or sticks from trees and even stove inside the glove box can find their way into the windshield cowling and into your blower motor..u can remove it to check by unplugging its white connector and remove the 8mm bolts that secure it into the heater core box..its very easy to remove..the 8mm bolts / screws should also have a phillips head on them...
Posted on Apr 17, 2009
SOURCE: I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Posted on Aug 27, 2009
SOURCE: Marvin Quartz heater element
Just ordered the equivalent of Marvin part #E1750 from Quartz Infrared Inc. Their part # is 50909 and is $17.95 Phone # is toll free 866-747-4328
Posted on Jan 04, 2010
Hi,I have an Alfa 2001 156 cigarette lighter not working found some fuses near the battery but not one for the cigarette lighter
Fuse box in passenger compartment Alfa Romeo 156.
fuse box location.
The fuses for the main devices are housed in a control unit under the dashboard, to the left of the steering column. To gain access to them, remove the panel (A) releasing the tabs (B) in the direction of the arrow below and remove the screw (C).
fuse box layout.
1 Ignition auxiliary circuits relay 1 2 Heated rear window relay 3 Horn relay F1 (10A) RH headlamp- high beam F2 (10A) Headlamp high beam warning lamp, LH headlamp-high beam F3 (20A) Boot lid/tailgate lamp, central locking F4 (10A) Headlamp adjustment, RH headlamp-low beam F5 (30A) Electric windows(front) F6 (10A) LH stop lamp, LH tail lamp, RH licence plate lamp, RH rear fog lamp, RH side lamp F7 (10A) LH licence plate lamp, LH rear fog lamp, LH side lamp, RH stop lamp, RH tail lamp F8 (10A) LH head lamp-low beam F9 (15A) Cigarette lighter, heater/air conditioning (AC) F10 (20A) Wind screen wash/wipe system F11 (20A) Horn F12 (10A) Alarm system, anti-lock brake system (ABS)(with ESP), audio system, instrument panel, interior lamps F13 (10A) Anti-lock brake system (ABS), central locking, electric door mirrors, electric windows, glove box lamp, reversing lamps, stop lamp (high level) F14 (10A) Hazard warning lamps F15 (30A) Door mirror heater, heated rear window
Sep 13, 2017 | Alfa Romeo Cars & Trucks
How do I set this timer Intertek 3075048 Model #YL-13M-1
Timer not identified via google search or image search.
Attach photo to identify timer
Otherwise this model number seems to be a fixya invention, or older timer that pre-dates internet
Following link has many timer manuals
http://waterheatertimer.org/Woods-timers-and-manuals.html
Gene
Water Heater Timers Save Money
Dec 09, 2014 | Hardware & Accessories
Electric fireplace
Heat and fan work fine for me, but the fire design for the logs and the wall wont turn on. I also lost the remote for it.
Jan 15, 2014 | Heating & Cooling
My intertek oscillating tower fan is not blowing. Oscillation feature still works....any ideas. model FZ-5
i have a intertek ocsolation fan i checked the fuse its good no power to unit
Jul 12, 2011 | Heating & Cooling
Heater will fire, will heat for one hour then shutdown. will get digital read out AGS. can turn heater off, let set for a while turn heater on will heat up for an hour and it will shutdown again.
you didn't indicate exact model but here is what the AGS is for.
Not sure if yours has a combustion blower or not, if so check that it's flow is not obstructed. If it doesn't make sure there are no debries in the flue area. Here is the troubleshooting from their manual. You can download a manual from www.jandy.com
AGS
(automatic gas shut-down)
1. Oscillating pump pressure. 1. Clean filter or identify and repair cause of pump
oscillation.
2. Low gas supply pressure. 2. Identify and repair incorrect supply pipe size or
pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners. 3. Identify and correct loose wiring connections, or
problems with igniter, flame sensor , gas valve, or
ignition control.
Jul 16, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Raypak pool heater is making a knocking noise
low water flow check manual bypass in heat exchange if spring broke letting too much water bypass and overheating water in unit also see if pump ok and filters
Jun 11, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Jul 10, 2009 | Marvin Dryers
How to reset Tilt Switch in LASKO Ceramic Heater 5540?
I don't have manual, it's a borrowed one. Several days later, I pushed the botton at the bottom several times, looks it solved my problem.
Feb 08, 2009 | Lasko 5540 Ceramic Compact Heater
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
