Question about Refrigerators
No water coming out of dispencer - Refrigerators
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Water dispencer from inside fridge isnt dispencing water. makes noise like it wants to but wont. can my water line be frozen? my fridge is usualy pretty bare and the temp is on 6.
It is very common for the water dispensing tube to become frozen if there is a slow drip coming from the water fill solenoid in the back of the refrigerator.
May 29, 2011 | Refrigerators
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
The water will not come out of the dispencer.
There is one water valve but two solenoids, one for the icemaker and one for the water dispencer. If power is getting to the solenoid then replace the water valve. No power getting to the solenoid then the switch at the dispencer is bad.
Feb 11, 2009 | Kenmore 53642 / 53644 Side by Side...
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Water dispencer
Remove the water dispenser assembly and check the pipes
Jun 23, 2008 | GE Profile¿ Arctica® Energy...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
