I have a double logo showing on dvd side when starting and picture is double also why how do i fix
3 Suggested Answers
  • 41 Answers
SOURCE: sony xbr-52in projection tv show double picture's
It sounds like a convergence problem. A fairly common reason for thisproblem is the convergence chips have failed. They are usually referredto as "STK" chips since the model number of these chips start with STK.I will put a link to another part of this site where someone has postedpictures and a link where to get the parts should you decide to fix ityourself. Look at Ecullier2012's posting. Jean's posted site will notfix this problem. Hope this helps you out. Let me know.
http://www.fixya.com/support/t1684874-screen_blue_green_green_red_outlines
Posted on Mar 16, 2009
rylee_smith
  • 8619 Answers
SOURCE: my phillip tv has started showing a double picture
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 11, 2010
Can vertical lines that start out in the middle of the screen be fixed
Generally no, this means that the connections from the edge of the lcd are failing.
Nov 26, 2015 | Vizio Televison & Video
When the dvd/hdd is on it not show any picture on the tv
Do it show its Logo on screen. If it shows the logo, and does not show picture, the fault is with its pick-up lens system. If it do not show the Logo too, the fault is with its main power regulator board [SMPS]. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 26, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
No picture but sound. When turning the tv on the
Power supply issues - I bet bad capacitors 'dried out' .
A good servicer should be able to fix it for you.
Nov 19, 2009 | Imation MLTD3222 32 in. LCD TV
Sony xbr-52in projection tv show double picture's
Mar 08, 2009 | Sony KP-51HW40 51" Rear Projection...
Double screen
There is a little black switch on the back of the DVD player that says progressive scan. Slide it to off. This worked for me.
Jan 06, 2009 | Memorex MVD2042 DVD Player
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Double image playing DVD's
check your picture in picture, sounds like your dvd imput is set for split screen, dvd on both sides
Apr 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
No picture on LCD
The LCD backlight has died. If it is still under warranty you may want to contact Mintek and see what they can offer you.
Aug 31, 2007 | Mintek DVD-1710 Portable DVD Player
Televison & Video Logo
Top Televison & Video Experts
