Question about Canon MultiPASS MP730 All-In-One InkJet Printer
How do you get a scanner to scan a full document not only a piece of it?
    Scholar:
  • 122 Answers
In a large number of scanners on the first pass it will offer a preview option. When it shows the thumbnail view you can drag an outline of what it thinks you want to scan out to cover the full page. Also you will sometimes have to tell it what size paper it is looking at from a small picture to a legal page. Check the scan settings and see if this info helps. Good Luck
Posted on Jul 21, 2009
Blank scan with neat desktop scanner
Connect the scanner to a different computer.
If you get the same result, then the scanner is "dead".
It's moving the scanning-head, but not detecting (or not transmitting) any "non-base-line" information.
Either that, or you have changed the CONTRAST and/or BRIGHTNESS settings to "wash-out" the image -- like looking at a "cream" coloured piece of paper in bright sunlight -- it may look "white".
Feb 03, 2014 | The Neat Company NeatDesk Desktop Scanner...
I need to copy a word document however when I scan it, it makes it into a jpg document. What can do I fix this in order to be able to edit and save the scanned document as a word document?
Make sure you installed the full software suite for your scanner. Scanners do scan to image files but should come bundled with Optical Character Recognition (OCR) software. Select the OCR option in your scanner settings and it will convert your scans to an editable format. Take note, OCR software is only as good as the scan, and the content on the paper, so it might make some mistakes, in which you will have to manually fix in Word etc "proofing"...
Regards, Chris
Jun 29, 2011 | Fujitsu fi-6130 Flatbed Scanner
My scanner is now adding a page with a black line that runs from top to bottom of the page and the actual document scanned is page 2. But the document is fine with no line through it. Does this mean that...
Check your scanner software settings. It is probably set at duplex ever time you start to scan. That is why you get two pages for every pass, the front and the back. You must place the document in the feeder in a way that the front side of the document is page 2. You may want to flip it next time you scan. So the main question is why there is black line from top to bottom? That is because there is a piece of dirt stuck on the glass of the scanner. You see, this scanner actually does two scanning when a page runs through it: the front and the back in duplex mode. So there are two scanners in side the box. The front page scanner apparently is dirty and needs to be cleaned with clean cloth and lens cleaner.
Aug 31, 2010 | Canon DR 3060 Path-Through Scanner
Black line in the middle of the output - scaned document
A black line down a scanned page indicates a dirty scan glass. Lift the top of you scanner like you would putting a page or book down to scan. On the end of the scanner that has the document feeder you should see a thin piece of glass the is separate from the larger glass pane. This is the document feeder glass. Now check it over for a very small mark of ink or dirt. You can use regular glass cleaner to wipe this glass just spray it on a piece of cloth not the scanner then wipe. You may have to wipe and then try scanning several times if the ink or marker is died on. while you are cleaning you should also clean the main glass pane, it will make the scans clearer and crisper.
I hope this helps, if so please rate our solution.
buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 05, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
HP 8270 does not scan on windows Vista . Could not complete scan is the error message
Make sure you have the newest vista drivers located here - also, make sure that the scanner platen is travelling the full length of the scanner, it's not being hung up somewhere causing it to jam. Try to scan while the cover is open to watch the scanner head travel.
Oct 21, 2009 | HP ScanJet 8270 Flatbed Scanner
Not scanning full page Canon DR-3080II/CapturePerfect
U should select 'Scanners maximum'  and try this. I have found this does not work midway, after some scans. So close and exit out of captureperfect, re-enter and try. This should work.
S. Mohan
Nov 19, 2008 | Canon DR-9080C Path-Through Scanner
Failure to open OCR documents scanned into Microsoft Word in a readable format
Have you installed OmniPage? What OS are you using? Which scanner did you have previously? Are you able to OCR a document through OmniPage?
Jul 26, 2008 | Canon CanoScan LiDE 600F Flatbed Scanner
HP ScanJet 5590 automatic feeder not working
Have you tried scanning in the flat bed mode? Does it scan okay? If the image is good, then there is no problem with scan module. Check your page settings. If the page size selected for scanning is smaller than actual size, there can be some peoblems. Try and scan with max size. Check if the sensors are dust/paper free. A small piece of paper (The small round discarded piece from Computer stationery) in the paper sensor can create trouble.
S. Mohan
Feb 21, 2008 | HP Scanjet 5590 Flatbed Scanner
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
94 people viewed this question
old marine
old marine
