Question about Drills
Drill stuck in reverse - Drills
    New Friend:
  • 121 Answers
Reverse lever internally seized
Posted on Jan 29, 2018
2 Suggested Answers
  • 384 Answers
SOURCE: my drill is stuck in reverse
Use left hand screws.....or take housing apart to see what has jamed the selector switch.
Posted on Jul 28, 2009
How do I take out a 5/8 auger bit that is stuck in a railroad tie? The drill won't move it ahead or in reverse.
Hey Doreen,
First, remove the stuck drill bit from the drill... You can drill "relief" holes around the stuck drill bit in a circle (use a 3/8" bit) and drill about 6-8 holes deep and close to the stuck bit.. this will relieve the tension on it and you should be able to wiggle the stuck bit carefully (don't break it) until it pulls out.
Jun 26, 2017 | Drills
Drill disengages when spinning
Could be several things. If it is a reversible drill, the selector switch could be stuck between forward and reverse. If it is a variable torque (popular on battery drills) the torque setting could be real low. Also, I've had this problem with the gears inside the drill wear out. No easy fix for that. If it is an inexpensive drill it would be cheaper to replace it than to have it repaired.
Feb 18, 2016 | Drills
How to reverse drill out of wall
If you are saying your drill bit is stuck in the wall..most drills have a reverse just put it in reverse if yours does not then just take the drill off the bit and get a pair of vise grips and squeeze it on tight and turn the bit backward it will come out..hope that is what you are asking good luck..
Jun 23, 2015 | Drills
How do I unlock the chuck to get the bit out
Finally got it the normal way. Put the drill in reverse. Hold the outside ring very firmly and slowly run the drill (in reverse direction). It was stuck. After about 5 bursts on the trigger, it finally came unstuck.
Sep 01, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
I have a drill bit stuck in the head. I put the bit straight in and now its stuck. Is there anyway to take it out?
Grab the drill head as hard as you can put the drill on drill setting and the highest number setting and put it reverse
Jun 09, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
The part where you put the drill in is stuck open
What you want to do is hold the tip of the drill firmly with one hand and pull the trigger with the other make sure the drill is in reverse though.
May 08, 2011 | Black & Decker Decker 14.4v Cordless...
Bosch keyless chuck stuck
Make sure you try it in both directions.
Apr 18, 2010 | Black & Decker 3/8" Variable Speed...
My drill is stuck in reverse
Jul 28, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Drill bit is stuck inside my makita drill chuck
Try using the low torque setting on the drill when reversing and something to assist you getting a better grip to hold the chuck from spinning when reversing. This may help.
Good Luck
Dec 02, 2008 | Drills
How do you get a stuck drill bit out of an electric drill ?
Stuck it in reverse as someone suggested.
Nov 14, 2008 | Drills
Drills Logo
82 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
