Question about Garden
The auger doesn't _disengage and the handle stays down
2 Suggested Answers
  • 2290 Answers
SOURCE: a white 8 hp 26 inch snowblower. the auger will not disengage and the handle stays down
See if a spring has let go where the handle hooks on. . There should be a spring to pull it back up when you let go of it.
Posted on Dec 22, 2016
Cub cadet 3 stage snow blower auger will not stay engaged when left handle is released as it is supposed to while holding down the right handle.
There is a little clip/notch/piece of plastic inside the dash right by the left handle. It's bent or broke.
Mar 16, 2017 | Cub Cadet Garden
A white 8 hp 26 inch snowblower. the auger will not disengage and the handle stays down
Dec 22, 2016 | Garden
The auger wont disengage on a mtD 8 HP 26 INCH SNOWBLOWER THE HANDLE STAYS DOWN
follow the cable to the auger either snapped or came loose
Dec 22, 2016 | Mtd Garden
Hi Brenda,
This machine makes use of two levers on the handle. The right controls the drive and the left controls the auger. When both are released, the drive wheels and the auger should stop. The impeller (the part inside that pushes snow up and out of the chute) will run as long as the motor is running and not controlled by the levers.
You said the auger continues to spin even when the lever is released. Both levers are connected by a flexible, thin, steel cable that extends down to a "wheel" or pulley assembly that is held in place by two hex nut bolts to the rear (operator position) corners of the machine. The steel cable should be ON the wheel - not hanging in free air and not wedged between the pulley and pulley support. Loosening the bolts and adjusting the pulley UPWARD should reduce tension / provide SLACK required to disengage the auger when the lever is released (adjust for a *small* amount of slack only). Positioning the pulley DOWNWARD increases tension that reduces the amount travel the lever needs to ENGAGE the auger. The pulley assembly position needs to be adjusted so that when the lever is released, the auger shuts off, and when squeezed, the auger turns on. These same adjustment procedures can be used for the DRIVE lever control, too.
If you are unable to adjust the cable so that there is a little slack, then there is a problem with the cable at the other end - inside the machine. It will require someone who is mechanically inclined - or snow blower serviceman to adjust / repair this for you if you lack the tools and understanding to do the work yourself. It is not likely to be an expensive repair, however. You should ask for an estimate or be given the opportunity to authorize repairs before they are started.
I hope this helps and good luck!
Mar 23, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
932 ariens shuts engine down as clutch is engaged to throw snow
Your problem would be in a safety shutdown switch.
some Ariens blowers have a two handed safety switch whitch is located on back of blower right lower side (inside of body)
You have to remove 4 transmission pan bolts to see it.
The other location is under the metal face plate between the handle bars.
Some of them have a third handel on right side of handle bars that has to be depressed to run auger .
Mar 01, 2014 | Ariens Garden
Noma auger wont stop spinning when disengaged
Sounds like either the auger belt is jammed to tight or handle mechanism to engage/disengage is stuck in on position. I would remove belt cover to inspect auger belt and pulley first, then remove bottom cover and inspect auger engage apparatus. I think once you inspect the problem will be self explanatory. Good luck!
Feb 18, 2014 | Garden
Craftsman snowblower auger handle won't disengage, won't come up
Any chance it won't come up when you have the "drive" handle down ?? Newer snow blowers are often equipped with a "one hand" feature that will keep booth the auger and drive handles engaged (down) with only one being held.
Jan 30, 2014 | Garden
Auger clutch lever disengages even though drive clutch lever is squeezed
On mine (Honda HS55) it turned out to be gummy old grease on the shaft and the lever that are supposed to lock the auger lever down. The spring couldn't overpower the sticky old grease. If nudged or given enough time, it would slowly turn and lock, but not instantaneously, as it should.
10 mm wrench to remove the nut (bottom left) and bolt (under handle) holding on the metal cover.
Once cover was off I could see the locking lever, spring, and the shaft that had the gummy grease on it.
The third photo shows the locking lever as it should be engaged. I had to push it to engage it, due to the spring not being strong enough for the gummy grease on the shaft.
There are flat sides on the shaft, behind the threads for the nut that has already been removed. Use a wrench on those to turn the shaft out. Disassemble. Clean. Oil. Reassemble. Works great now.
Another possibility is that your locking lever or spring are broken.
Dec 17, 2013 | Honda Snowblower Cover Silver Hs928,...
How to adjust a 9460897 mtd snow blower auger clutch cable.
On the handle end (usually) of the cable is a curved metal connector. Attached to the connector is a threaded rod with a nut. Attach a pair of pliers to the threaded cylinder that the threaded rod goes into. Loosen the nut. Turn the threaded cylinder into the threaded rod to tighten or out to loosen. When you have the correct adjustment, tighten the nut back down onto the cylinder. To be correctly adjusted, pull the cover off the auger belt and push down on the handle. The spring attached to the cable at the pulley end should stretch out when the handle is fully depressed. Spring tension keeps the belt tight. iaff801.jpg
Feb 15, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
Craftsman snowblower auger won't disengage. Tried adjusting cable but that has no effect.
check the belt there is a tensioner on mine the work to tighten the belt when you pull the handle there may be something in there that is not letting it release all the way
Feb 22, 2010 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
