Question about Toys
Spot light not coming on on santa train car,can it beasy repaired
3 Suggested Answers
SOURCE: Airblown inflatable santa train. It will not
I installed my outdoor christmas lights, they lite up fine and about an hour later they stopped working
Posted on Dec 07, 2009
adamfjeld
  • 1508 Answers
SOURCE: i need and instuction manual for the santa fe ride
i have the manual if you still need it
Posted on May 22, 2012
I can not wire my new angeleye spot lights on my 2002 hyundai santa fe to the exsisting wires they are live all the time
Angel Eyes can be fitted to any motor vehicle!
Having not fitted these specific lamps before, the general idea is as follows:
Spot lights come with a +Ve terminal for the power & a -Ve for the ground (earth) and a possibly another wire for the angel eye itself.
You need to confirm if there is an in built relay already within the spot light unit which makes things more complicated.
Generally - standard spot lights:
To connect to a vehicle , you must introduce an in-line fuse + a relay to handle the load of running the two lamps. The relay has four terminals, 1) trigger terminal directly to the Main beam wire of your headlamp (white), 2) +Ve directly from the main power to the engine bay fuse box (red), 3) Earth directly to the ground of the vehicle or battery (black), 4) Power to your lamps (red or yellow or white).
Above is only a guide, you can assume two wires will certainly be power to the bulb and earth. Confirm what you have got, circuit diagrams are a must, always use correct grade of wire otherwise you will overload and overheat the overlay harness between spot lights and relay etc....
Thanks.
Jan 21, 2010 | 2001 Hyundai Santa Fe
Nov 24, 2009 | Carousel Airblown Inflatable Christmas...
My son poured water in his peg perego santa fe ride on train
It might have shorted out the motor under the seat.
I would contact the repair help at
http://www.shopjandl.com/
Jun 19, 2009 | Peg Perego Santa Fe Express Ride On Train
2001 Hyundai Santa Fe 78K miles on it...purchased 8/04 began having problems 10/08. Car starts no problem. After sriving for 10 minutes when coming to a stop the car feels like it does not want to stop,...
TRY THESE TWO (2) THINGS..
Step 1: Disconnect the battery cables and touch them together for 30 seconds (this ZERO'S out the PCM/ECM (Power Train Control Module/Engine Control Module). If there's GARBAGE in memory of this computer (PCM/ECM), this should CLEAR it.
Step 2: Check the Throttle Position Sensor (TPS, it's a potentiometer) for any ERRATIC resistance changes at idle position or any other position for that matter. If you find, what I call BAD SPOTS, in the TPS, replace it. I know of NOTHING ELSE which would cause the problem you describe and NOT turn on the "Check Engine" light
May 03, 2009 | 2001 Hyundai Santa Fe
2004 Santa Fe Tail Light wire connection
Now that you have the screws out, you need to pull away from the front left (driver spot) or right (passenger side) depending on which tail light your replacing. There will be a small tab in the corner closest to the vehicle, undo the clip and it will come out clean and easy!
You might need some needle nose pliers :)
Apr 04, 2009 | 2001 Hyundai Santa Fe
Toys Logo
69 people viewed this question
Top Toys Experts
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
