SOURCE: left ge stainless steel fridge and freezer door open acciently
youll need to unplug and defrost all the ice from hte back panel, leave unplugged for a min of 24, hours, then plug back in you should be fine. way too much ice has built up behind hte inner panel ,cutting of all air flow to both compartments.you did no real harm( other then losing your food
SOURCE: SENSOR PROBLEM ON SAMASUNG SRS580DW (side by side fridge)
go ahead and take and hold in the top two button until the unit blinks and resets the controller. Please don't rate this unitl the problem is solved because i can't come back and answer any more questions then. Also if this fix's please rate this solution please. Thanks for usin FixYa
SOURCE: Fridge worked perfect for 3yrs, one day i took
you may have a big problem not sopose have the door open so long better you call service
SOURCE: Door left open, now fridge won't work right.
Shut down the fridge for 10 - 15 Minutes and leave the fridge door open, and push the Defroce button
ANd start the fridge again and after some time check the temp.+ after some time.
Thanking you,
Your Tech Support
Manish Shirsikar,
Fixya.com
