Question about Garden
I need to know how to start my weedeater barracuda sv30 .. I got it off someone so its used the first time i got it i got it to start but after that i can get it to start again no matter what i do
3 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: I have a weedeater barracuda sv30 blower had it
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
alpug
  • 1961 Answers
SOURCE: I require a manual for
Hello!
here is the user manual, you must have adobe acrobat reader installed in your system to view this file because its pdf format.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0403164.pdf
and for the parts and where to purchase it, click the link below
http://www.searspartsdirect.com/partsdirect/part-model/Weedeater-Parts/Leaf-blower-Parts/Model-BARRACUDASV30/1323/1503110
Posted on Jun 26, 2011
How to unblock youtube from pacyber
Hello. i do Pacyber and i figured out how to safely unblock the barracuda ****. You click on the little windows button in the bottom left of the screen. From here you will need to type in the search bar located at the bottom the the window that comes up. Type in RUN and click on it. From here a box should come up and type in services.msc. without the period lol... and once you have typed that in you click ok. a lot of **** will come up. look for Barracuda WSA Service and Barracuda WSA. once you have found these you must double click it ethier one. once you have done that make sure you are on the general tab of that window that opened. Look in around the middle of the page and you will see Start up type. it will say automatic or anything EXCEPT disabled. click on that thing that should say automatic or manual. put it on disabled to BOTH Barracuda things and also make sure to STOP them but going under the start up type. it will be listed start stop pause and resume. click STOP . Do these steps to each of the Barracuda things only. Im sorry if this was difficult to follow it was my first tutorial and im only 14 so dont get a big **** about it. let me know if it was helpful or if it didnt work. this will enable you to use ANY website you disire. HAVE A GOOD *** DAY
Oct 23, 2011 | youtube.com
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
So I know the password to my barracuda web filter, but whenever I attempt to go to a blocked site (where on the rest of the computers in the building, it directs you to a page with a barracuda log in...
Probably a DNS problem, and it is possible you are not authorized to log in, despite your knowing the password. They may have turned off the ability to enter a password for your username.
Apr 23, 2010 | Barracuda Networks Barracuda Web Filter...
I have a weedeater leaf blower that will start when I put gas in the caberator but will not run otherwise
sounds like the carby needs an overhaul. bellows in carby that **** up fuel may need replacing
Jun 30, 2009 | RTO Weed Eater Electric Barracuda 2595...
Seagate Barracuda 7200.10 500GB Video Included. Humming, Wobbling
Brother,it is a firmware problem for seagate drives,the 7200.10 has a typical problem of firmware,once it currupt,then it cannot be detcted by the BIOS or PC ,or showing 0GB or less capacity when connected,so you can use some useful tools such as HD Doctor for Seagate to repair it,this problem is very common but less tool can deal with it till now.
Jun 28, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I have a weedeater barracuda sv30 blower had it for years worked great. Today after looking at it and not starting today and hard to keep running 2 weeks ago I looking in the gas tank and pulled the fuel...
Jim
Jun 21, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
My sv-30 blower will not continue running.
Have this problem currently with my WeedEater SV30, and I suspect the filter fuel line has rotted off where it passes into the tank. Had exactly this problem with my cheepy trimmer and was able to replace the fuel line. Hopefully I can do the same with my SV30 blower. Seems like the gas line material does not like the ethenol in today's gasoline...
Mar 28, 2009 | Garden
Putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Oct 10, 2008 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
