Question about Kenmore Kitchen Ranges
My Kenmore Ultra Temp oven does not turn on. The burners all work fine. But I am unable to bake or broil. I tried both convection and conventional. Model #: C968-68822-1. Please help! Thanks, Mindy
  • Mindy Wilson Dec 22, 2016
    We have not had any power outages, I did try unplugging it and plugging it back in. No error codes either. Only when I go to press "start" - the whole display stops like I pressed "clear"
    Top Expert:
  • Kenmore Master
  • 41,491 Answers
Sadly , it is time to call a repair tech .
Posted on Jan 01, 2017
huuum
  • 750 Answers
SOURCE: electrolux built in wall oven,
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Posted on Oct 16, 2008
  • 71 Answers
SOURCE: Oven will not bake, but broil works
the bake ignitor is most likley bad
Posted on Dec 24, 2008
  • 109 Answers
SOURCE: Kenmore Oven - neither the bake or broil work, dial doesn't light
these elements burn out over time so chk. that out
Posted on Aug 23, 2009
protek480
  • 1714 Answers
SOURCE: Why does the surface burners and broiler light but
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Posted on Sep 11, 2009
SOURCE: Frigidaire conventional oven won't heat up
My frigidaire model is CPLEF398CCB conventional electric flat top oven. Everything is working fine except my oven. When I select pre-heat, broil or bake nothing lid up. No heat on the coil, only fan.Any suggestions?
Posted on May 09, 2011
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Apr 09, 2010 | Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Kenmore electric range 790. Both the broil and
Kenmore oven 790.91072601, bake & broil not working, relays are cycling but no heat... Sounds like I have the same problem but its the night before Thanksgiving and Iam in panic mode... I've orderd a new Temp Probe part # 316233902. did you ever get yours fixed
Jul 13, 2009 | Kenmore Kitchen Ranges
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
Hello stevefer
Welcome.
First,
Huuum
Oct 16, 2008 | Kitchen Ranges
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
Kitchen Ranges Logo
46 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
