Locate the two top auger housing fastening bolts and remove. The auger housing will tilt forward and then lift the housing off of the bottom 2 bolts/bushings. You will need to support the traction frame as it will try to fall onto the handles.
Either there is a belt or a chain off, or the linkage became disconnected or there is a pin sheared. Take one of the three. If you have power spinning like you said then those are your choices! Best of luck to you. Hope you beat the weather!
That looks like a Cub Cadet part # for the Snow Blower.
You will absolutely need to customize a Belly bracket and Mule drive. Possibly find a Cub Cadet belly bracket and modify it to match your mounting points on the TY4000
Any chance it won't come up when you have the "drive" handle down ?? Newer snow blowers are often equipped with a "one hand" feature that will keep booth the auger and drive handles engaged (down) with only one being held.
The manual has a step by step procedure for adjusting the cables for the auger, speed selector and drivewheels. One socket wrench and about 10 min should do it.
My Yardworks is an MTD product and it's manual should be similar to yours. If you lost it, you can download it from MTD's site.
