Question about Tappan Ovens
I have an old tappan wall oven and it won't turn on due to clock and timer can I bypass to make oven work
  • Mikey Martellaro
    Mikey Martellaro Dec 22, 2016
    I set the timers and the oven on light turns on but the oven won't heat up please help
  • 833 Answers
SOURCE: tappan oven won't turn on after cleaning
I don't precisely understand...responding. I assume that if you say oven on that the oven isn't heating but the indicator controls are working. This has several possibilities. First, do turn your circuit breakers off then on...there are two linked together. This may reset something. If that fails, your problems are likely in either the high limit safety switch or the heating elements. The elements are more likely. To check them, turn off the power and remove them from the oven. This is usually by taking out one screw and unclipping the element. See if the element is bulged or damaged. If not, use a multitester to see if one of them is not conducting. Replace it. High limit should conduct fully. Use the curcuit diagram on the stove to determine its location.
Posted on Dec 28, 2007
SOURCE: Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Posted on Mar 19, 2008
Maytag317
  • 1136 Answers
SOURCE: I need to replace the
Hi, As long as the wires connecting the ignitor are long nough, you can do this while the oven is in the wall. They usually come out far enough. Make sure the oven is unplugged or the breaker is turned off. It is fairly simple to change.
Please let me know if this helps you or if I can assist you further.
Vic
Posted on Jul 11, 2009
SOURCE: Tappan gas oven won't turn on
I cannot assist you with your problem, but I do have the same oven and it seems the control panel doesn't work either. However, I am looking for the manual. Would you perhaps be able to help me with that? Sincerely, S. Rozier
Posted on Apr 07, 2010
  • 22 Answers
SOURCE: I have a 40 year old Tappan electric wall oven. It
I have one of these too. the TOP small clock should be set to the time you want the oven to start and the BOTTOM small clock should be set to the time you want it to turn off. Be sure to set the oven settings to what you want and the correct temperature.
Try testing it first just to see if it works correctly. It's also important to make sure the other large clock on the oven is set correctly.
Posted on Sep 27, 2010
How to bypass broken clock on eurolec 720ef electric wall oven
If you bypass the clock, how will you maintain a steady temperature, include safety features, or program functions?
What you seem to want is an outdoor grill. DO NOT bypass the logic board on your oven, sir. Help Me Find My Model Number RepairClinic com
Jun 14, 2016 | Ovens Ovens
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
I have a 40 year old Tappan electric wall oven. It has an analog clock with 3 timers on it (2 small timer...stop and start and a large timer with 3 hands on it). Which position do the timers need to be for...
May 01, 2010 | Ovens
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
Tappan electric wall-oven always says off ????
Check that one of the two hot wires is not losing power due to bad connection. This needs to be checked clear from the breaker to the terminal in the oven. Loss of one side of the 240 volts may still allow the clock to work as long as no other element is on.
OFTEN the connection of to the plug in the wall is bad... IT IS ALSO a fire hazard.
REMEMBER to turn off the breakers when working on this!
Aug 28, 2009 | Tappan 30IN ELEC IGNa Oven
Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
Ovens Logo
55 people viewed this question
Top Tappan Ovens Experts
ashburton
Craig Butler
Craig Butler
john h
Are you a Tappan Oven Expert? Answer questions, earn points and help others
