Question about Lakewood Heating & Cooling
I have a Lakewood model 5500. The on switch lights up when I plug it in but the unit does not get hot at all. Am I able to get a new thermal fuse or thermostat for this unit ?
SOURCE: Lakewood oil filled heater model 5500
Follow up to my post of 13 January. Out of desperation, I took the heater apart and determined that an electrical fuse-like thermal overload device had opened on the neutral side of the feed to the heating element thus rendering the unit non-working. This device is wrapped in a sheath around the underside of the heating element's electrical connections where the element enters the radiator's core. If the element exceeds the rated temperature it apparently "blows" or electrically opens much like a fuse. The lights still come on but no electricity is getting to the element. When I removed this from the circuit, the the unit began making heat. Apparently, when the heater is on full (both switches on for the full 1,500 watts) the core temperature gets too high. So, I now use my heater on only the 900 watt setting and it's putting out plenty of heat. Today's high is 2F and the room is comfortable. I've no doubt the manufacturer would not condone this modification and I have no intention of turning my modified heater back on "HIGH." Therefore I do not recommend doing this yourself unless you are competent in electrical and soldering work and are sure you won't overheat the unit. Having said that Lakewood clearly has either a design flaw or a bad batch of heater elements or overload protectors out there. When I have time, I'm planning to send my defective protector back to them with a letter. But given that they never responded to my e-mail to their customer service don't expect much in the way of a reply. As they say on TV, don't try this at home.
Posted on Jan 31, 2008
  • 34 Answers
SOURCE: i need a wiring diagram for a lakewood 5500
Visit this page for service center info and or parts: they should be able to help you http://www.lakewoodeng.com/html/parts.html
Posted on Apr 18, 2009
  • 34 Answers
SOURCE: lakewood radiator 5500 heater scehmatic
visit this webpage for service center and parts: http://www.lakewoodeng.com/html/parts.html
Posted on Apr 19, 2009
SOURCE: The Lakewood 5500 oil-filled heater has stopped
Similar problem here. But in my case, it was a blown fuse. There's an in-line fuse on the internal wiring of the heater. Take the control-side off (remove the bottom grey plastic bracket, then remove a sheet metal screw, then slide the whole assembly down off of the radiator). Where the elements go into the reservoir at the bottom of the radiator, the white wire should have an inline fuse connected to it. It will probably be covered with what looks like heat-shrink tubing. Snip, snip, and replace.
Posted on Jan 11, 2010
  • 3 Answers
SOURCE: Lakewood space heater thermostat source
If it is a Ksd31 thermostat you need, you are in luck. I found what I needed for my model 5600/7 on ebay. The store Larksining sells the for as few as five/pkg in various temp. settings. I got 5 ea. in two temp settings for less than $11.00 USD with shipping from Hong Kong.
Posted on Jan 26, 2010
Need a thermal cutoff for our Lakewood 5500
We have these heaters and haven't had a fuse fail yet. I think it's because after the first time I got that crackling sound after moving it while it was on, I stopped doing that, and only move it with the power off, and wait two minutes before restarting it, so the oil can resettle.
However, the thermostats are now failing. Anyone know if this part is available?
Apr 10, 2010 | Lakewood (5500) Oil Filled Radiator Heater
My lakewood oil filled heater model 5600/7 just stopped working. It won't turn on..no lights. There is no history of tipping over.
The reason that it stopped is an open circuit. It is probably a blown thermal fuse. However, it could be any of the following if that is not the problem:
bad switch, broken or disconnected wire, burned open heater element, bad connections between terminals and wires, or between wire connectors and the wires within them.
If you take it apart, you will find the heat sensitive thermal fuse device under the heating elements, near the bottom of the unit. If the thermal fuse is good, it will appear as a short to an ohmmeter (zero ohms). If it is failed, it will appear as an open (infinite ohms).
The thermal fuse device can be replaced. Here is where to get one:
http://www.goodmans.net/get_list_632_2.htm
The thermal fuse may be this one, but check the temperature indication on yours first: Item#: TH-TF167C
Good luck.
Apr 06, 2010 | Lakewood (5500) Oil Filled Radiator Heater
No lights on switch on--no heat--on LAKEWOOD mODEL 7000/A
Look for a thing called a Thermal Fuse, small, pencil sized cylindrical, silver, (usually) with stiff lead at each end. It should be in the Phase/Active line. Try replacing that.
Feb 12, 2010 | Lakewood Oil-Filled Electric Radiator...
The heat no longer comes on.
The Lakewood 5500 heater may not heat, yet all lights are on, due to the thermal fuse inside the control box being blown.
It works like a normal fuse, yet will blow if the temperature gets too hot. When it opens, it will prevent any electricity to get to the heating coils and connot be reset. It must be replaced.
You can open the control area by removing the front foot of the unit, removing another screw behind that foot. This will allow you to slide the whole control end off the unit. At the bottom next to the heating element, you will notice 3 wires to the elements - red, blue, & white.
The white wire runs underneath the terminals & is sheathed. Under this sheath is the thermal fuse.
Be sure to replace it with the same temperature rating (167 C).
I don't recommend bypassing the thermal fuse, however, due to it's a safety issue.
I found the fuse at the following link:
http://www.goodmans.net/get_item_th-tf167c_thermal-fuse-167-degrees-celsius.htm
Mar 25, 2009 | Lakewood (5500) Oil Filled Radiator Heater
Lakewook oil filled radiator heater
Here is your problem and yes it can be fixed.
More than likely your thermal cutoff tripped because your heater got too hot.
Solution:
1. Unplug unit.
2. remove front support feet and screw underneath face plate will slide off.
3. You will see the heating element, a white wire is coming out of it. There is a white sleeve on the wire tucked up into the element. Pull the wire out and slide sleeve off to expose the thermal switch labeled (S.W.C. sw-120t ect.) You can google it to learn more about the cutoff. If you know how you can test the cutoff with a ammeter or voltmeter, If you don't google how to test electrical systems. Remember "first do no harm"
4.
a. If you can replace the cutoff do so (this is the recommended way)
b. If you don't want to replace it cut the cutoff out and solder the wires back together. (be warned that this will bypass the safety system) If you do this be careful to not leave your radiator unattended.
5. After soldering the wire, taping it will electrical tape. Replace face plate from step 1 and 2 and your heater will work.
P.s. If your heater is still under warranty just contact lakewood.
Jan 20, 2008 | Lakewood (5500) Oil Filled Radiator Heater
Lakewood 7096 heater
Some of the newer models have a thermal fuse which may be blown. It doesn't look like a normal fuse at all. It is similar to a transistor in looks and should have continuity from one end to the other. It will be tied in to the incoming power cord inside the heater, and may be covered with rubber coating within the wire. It will look different when you notice it. Sometimes its too far down inside where the heat causes it to blow prematurely. The purpose is to cut the power to the unit in case it overheats. You can get one at radio shack for less than a couple of bucks. The older models don't normally have one, but I would suggest you put one in it if that's the case.
Dec 16, 2007 | Lakewood Oil-Filled Electric Radiator...
Dec 08, 2007 | Lakewood (5500) Oil Filled Radiator Heater
Lakewood 5500 Oil Filled Electric Radiator Heater
same problem. good for one winter. stop working the next though the light is on...
Oct 30, 2007 | Lakewood (5500) Oil Filled Radiator Heater
Heating & Cooling Logo
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
