Question about Yamaha Audio Players & Recorders
Yamaha swoo12 Green light is on . Volume up. No sound. Is there a fuse on this unit.
    Habit-Forming:
  • 195 Answers
There is a fuse but if there is not sound it is either that the system isn't connected correctly or the safety circuit has cut in as there is a problem.
Posted on Jan 06, 2017
There is a 'green' light, but no sound in the earphones, volume does nothing?
check the input to the base unit,and check the volume control on the headset..also put new batteries in the headset.Mine are a rechargeable type and are useless.BUT dont put headset back on charging stand with ordinary batteries in
Aug 12, 2014 | Audio Players & Recorders
My Yamaha YST-M101 speakers are not playing any sound at all. They are plugged in correctly and the green light turns on when I attempt to turn on my speakers. Help?!
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Aug 23, 2011 | Yamaha YST-M101 Computer Speakers
Volume not function.
You need to be a bit clearer on the exact nature of the issue.
Please include if the unit was working and suddenly stopped producing sound (ie - speaker output fuse blew) or if you relocated the unit, and after hooking it back up, you aren't getting any sound (ie - not hooked up right) or if the volume knob isn't changing the readout for the volume level (logic or knob broken) - and also include the make and model of WHAT the volume knob is attached to (ie - Yamaha receiver model X)
Feb 22, 2011 | JVC Audio Players & Recorders
Green led light is on but no sound comes out
hello
check the leads from the source and to the sub.
use the remote to turn up the volume on sub.
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Yamaha YST-SW800 Subwoofer
Red light and beeping as if its not charged but green charge light turns on when i charge it. no sound from babys room
I just fixed my unit that had this same problem. You have to re-pair the two units... Turn the parent unit off. Hold the "volume down" button while you turn the parent unit back on. The unit should beep and flash all volume lights. Release the volume button and the press again for ~2 seconds. The volume lights will light up and stay on. Next, turn the nursery unit off and then back on. This should re-pair the two. I hope it fixes your problem!
Aug 03, 2010 | Graco Digital Deluxe Imonitor Baby Monitor
Volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
Aug 02, 2008 | Yamaha RX-V659 Receiver
Volume light blinking, no sound.
Plug in some headphones as they are usually always active and see if you get any sound and volume control of them.
if not the switches may be stuck .
or the output fuses blown.
it gets sticky to work inside one of these without electronics experience and you can do more damage.
The fuses are about all you are allowed to fix.
Jan 05, 2008 | Yamaha RX-V992
37 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
