I have a wall heater ch 30-2 does it have a thermostat or can you install one
2 Suggested Answers
SOURCE: How to install a wall dimplex thermostat to a
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Posted on Sep 21, 2010
Is the sunvic sp2 a 2channel timer please
Yes. It appears the Sunvix SP2 is 2-channel timer.
Two-channel means CH central heat and WH water heater can be programmed separately, and each can have its own timing program.
pg 3
The timer offers pre-programmed options for both CH and WH, which can be used, or program your own schedule. chart pg 5 and steps pg 3
Limitations: both channels operate on same clock time, and dip switch setting. pg 6. So the WH cannot be programmed for 5-2 weekdays-weekends and CH programmed for 24 hour.
As a convenience for varied work schedules, Sometimes people use the 5-2 weekday-weekend option so 2 days of week can have different programming, and then fudge current day setting during the set-current-time step pg2 so the 'weekend days' are actually moved to wedsday-thursday instead of sat-sun.
Option: both CH and WH timer programs can be linked and follow same programming by using copy button. pg 5
Using advance button on either side of timer, pg 3-4, WH and CH timing schedules can be overridden temporarily until next set point is reached. Then regular programming automatically resumes.
If override or Advance button is pushed for either CH or WH, it reverses whatever programming is in effect. On becomes off, or off becomes on. However if CH thermostat is satisfied and room temperature has not fallen below thermostat set point, then override will not turn CH on, but override will turn CH off. Same for WH override: If cylinder thermostat is satisfied with internal water temperature, the water heater will not turn on and heat more water, but the override can turn water cylinder off.
Unit requires Cr2033 lithium button battery. Pg 6. Probably lasts 3-5 years. Programming is protected for 30 days from power outage.
If programming is lost, change battery, the reset timer and reprogram to restore functionality.
Nov 24, 2012 | Hardware & Accessories
Installed new wall heater and thermostat and pilot is on but heater will not come on?
What about thermostat wire? What ya got 2 wires right? Touch them together she supposed to ignite the flames then after a few minutes the fan kicks in on fan models. You got the knob on the gas valve turned to the "ON" position?
Nov 07, 2011 | Williams (5009622) Ceramic Gas Wall...
I want to buy form Costco a Sylvania Convector 2000 watts with built-in thermostat. I already have a wall electronic programmable thermostat.can I install this convector anyway and not plug the built-in...
No, you will only be able to use the heater's Thermostat.The programmable wall thermostat you already have is either an 18 volt or 24 volt thermostat. It won't work with a portable electric heater.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Heating & Cooling
New wall heater installed but after a couple of minutes it turns off by itself but thermostat says on.
The problem may lie in where the wall thermostat is placed. If it's too close to the heater, the heater is shutting off prematurely. However, I'm assuming the plot stays lit after the burner turns off.
The Thermostat should not be in the path of a warm air discharge from the furnace, a lamp, TV set, etc.
If the installer did not leave you the Owners Manual, here's a link to it, in a pdf format that you can print and have for future reference.
Please let me know how it worked out for you.
Feb 16, 2011 | Williams (5009622) Ceramic Gas Wall...
You want spring-operated 30 minute countdown timer for 240Volt electric heater.
You don't say how many watts your heater is.
Answer is longer without knowing watts.
1) As you know, you can turn off any 240Volt circuit by turning OFF one hot leg.
People are skeptical when working with 240 V and believe both hot wires have to be turned OFF.
But you know the heater needs both hot wires. Disconnect one hot wire and see.
240V water heater thermostats operate in this way ... they turn OFF 1 hot wire.
2) Intermatic FF30 and FD30 series timers can directly turn off 1 leg of 240Volt 2500 watt heater.
Max 2500 watt, no more.
This Intematic timer is rated for wattage shown. With other brands, check the rating.
Amazon sells FD30 30-minute
3) Intermatic also makes DPST timer if you want to turn OFF both hot wires
Aplussupply sells FF and FD Intermatic timers, and 30-minute DPST model FD430M
The rating is same as shown above.
4) If your wattage is greater than 2500 watts, then you need to install a 30amp contactor with 120Volt coil. Timer turns magnetic coil on-off, coil opens and closes contacts that turn heater on-off. You can use any ordinary light-weight wall timer with a contactor.
5) Following page gives you information for installing a contactor to handle 240Volt loads up to 5500 watts.
Pages show how to wire, where to buy, what to buy.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 26, 2011 | Hardware & Accessories
Blank display on ideal isar 2 he 30
may just be a defective display PCB, byt more often than not, its the more expensive main primary PCB. Ideal actualy modified this PCB, and has a pre-fix of VF on it, and is orange in colour
Feb 18, 2009 | Honeywell Programmable Thermostat Heater
Heater goes out after 10 to 30 seconds.
sounds like a blocked pilot when you turn on the main gas takes the gas away from the pilot and goes out
Nov 08, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
