Question about Food Mixers
Beater for Durabrand SM Mod 0112 good mixer beaters real hard to find
    Top Expert:
  • 46,465 Answers
SOURCE: Beater does not turn
It sounds like the nylon gear is stripped out. It is a rather easy to replace and also inexpensive. A gentlemen posted a step by step site to replace the gear. The link is http://www.neilcrockett.com/mixer.htm
Good Luck
Posted on Dec 07, 2008
SOURCE: Kitchen Aid Stand Mixer won't release beater
I had this same problem as well.  The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure.  I tried the cooking spray and it did nothing.  But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater.  I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes.  When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer).  It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft.  But it did finally come off.  After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off.  So, I put a little bit of veg. oil on it, and it seems to be better.  Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking.  Best of luck!
Posted on Feb 21, 2009
SOURCE: Beater keeps falling out. The
Sunbeam 2366 stand mixer -- Front view: mixer-0-small.JPG -- 0d345a3.jpg-- image of the "beater clip": mixer-1-small.JPG -- notice the wear on the plastic clip --8982711.jpg -- image of the "modified" beater: mixer-2-small.JPG - I took a paper clip an wound very tightly to the smallest diameter (notice it covers the entire section to prevent slippage) and then put one wrap around the "top knot" to increase diameter --d67ddea.jpg -- image of the back of the front cover: mixer-3-small.JPG - notice the broken clip at the top. I used a wide scrapper blade to separate the cover from the main body. 3297c2c.jpg----
Posted on Sep 13, 2009
SOURCE: Where can I find a flat beater for Wolfgang Puck 600 Bistro Mixer
I contact Wolfgang Puck directly. Thanks
Posted on Nov 19, 2009
hslincoln
  • 235 Answers
SOURCE: Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Posted on Nov 28, 2009
Testimonial: "Thanks to this answer, I was able to fix the problem in about five minutes. I am very grateful. Joe McCutchen"
Stuck beater
The shaft of the beater is bent. After frustrating discussions with Cuisinart customer service, I was able to free my shaft. First, you will notice that the beater screws onto the shaft. Unscrew it. Then, take the nut off the shaft. Next, put a wrench on the shaft that is only slightly larger than the shaft, followed by a washer. Next, screw the nut back onto the shaft. Finally, holding the wrench at the end, hit the wrench close to the shaft with a hammer. If the shaft doesn't come out, hit harder. Since the shaft is bent, you'll need to purchase a new beater.
Feb 08, 2014 | Cuisinart SM-55 Stand Mixer
Beaters are stuck in the mixer
The shaft of the beater is bent. After frustrating discussions with Cuisinart customer service, I was able to free my beater. First, you will notice that the beater screws onto the shaft. Unscrew it. Then, take the nut off the shaft. Next, put a wrench on the shaft that is only slightly larger than the shaft, followed by a washer. Next, screw the nut back onto the shaft. Finally, holding the wrench at the end, hit the wrench close to the shaft with a hammer. If the shaft doesn't come out, hit harder. Since the shaft is bent, you'll need to purchase a new beater.
Dec 24, 2013 | Cuisinart SM-55 Stand Mixer
Need beaters for a black and decker SM100 mixer
I searched for replacement beaters for Blacker & Decker SM-100 type 1 (SM100) electric stand mixer for years. I found the Sunbeam Mixmaster Mixer Replacement Beaters for stand mixers, item 4955, at a large Ace hardware store. They were priced over $16.00, so you may consider buying a new stand mixer. The beaters are the correct length, snap in and grip correctly even though the ends are curved like a half ball rather than flat as the originals. The beaters turns well but I haven't tested them with the bowl because I need to find the turn table that I have in storage. The beater set was design ed to replace parts for Sunbeam stand models 2355-1, 2356-1 and 2360-2.
Jan 18, 2012 | Black & Decker Food Mixers
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
Beaters will not move
You have probably stripped a gear in the gear housing. Here is the breakdown of the gearbox:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
The newer "more improved" mixers use plastic gears and they can't take the beating, no pun intended, and fail.
The good news is that the most likely gear to fail is cheap. Here it is on amazon.com:
http://www.amazon.com/KitchenAid-W10112253-Worm-Gear/dp/B0006HLAVA
http://www.misterfixit.com
Mar 25, 2010 | KitchenAid KSM150PS Artisan Series Stand...
I need replacement beaters for an old GE hand mixer.
I bought an old GM mixer no. 30M47 with no beaters yesterday at the Salvation Army store. The beaters I have for a newish (ugly) GE hand held beater fit perfectly. I suggest taking your old beater to a store that sells new GE handheld beaters and seeing if the new beaters fit. If anyone reads this and wants me to look up the number of the new ugly beater for them, please say so before I take it to the Salvation Army.. : )
Oct 21, 2009 | Black & Decker MX55 PowerPro Hand Mixer
The beater shaft seems jammed. I can't push it up to remove my beater.
best returned to service centre as these are very hard to get apart.
Sep 15, 2009 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid Hand Mixer Beater won't stay in slot
You need a new gear set.  Hard to find however.
Jan 07, 2007 | KitchenAid KHM3 Classic Hand Mixer
Food Mixers Logo
60 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
